Alerting On A Batch Job Stream
To receive alerts on an active batch job stream, edit the batch job stream and add the desired level of service algorithm on it.
Note: Only algorithm types are delivered for Batch job stream level of service algorithms. A corresponding algorithm must be created before it can be added onto the batch job stream
Following level of services are currently supported on batch job streams
  • Batch Job Stream has not started within ‘X’ minutes
  • Batch Job Stream has failed
  • Batch Job Stream ran too long (relative run)
