Defining Units of Measure
You use the Unit of Measure portal is used to display and maintain units of measure.
Refer to  Understanding Units of Measure for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Unit Of Measure.
The following zones may appear as part of the portal's Main tab page:
  • Unit of Measure List: This zone lists all units of measure. Broadcast a record to display the details of the selected record.
  • Unit of Measure: This zone provides information about the selected unit of measure.
