Defining Cost Centers
The Cost Center portal is used to display and maintain cost centers.
Refer to Understanding Financials for more information.
You can access the portal from Admin, select C, then select Cost Center. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Cost Center: This zone provides financial information for the cost center as well as account segment details used to create the general ledger account number.
- Cost Center Monthly Statistics: This zone displays a graphical view of monthly statistics for the selected cost center.
- Valid Expense Code: This zone displays valid expense codes for the selected cost center.
