General Data Setup
This section lists entities typically performed by an administrative user and are accessed from the Admin menu. Most of these objects establish global configuration. They are defined at implementation and usually do not change again.
Level |
Entity |
Comment |
1 | Defining Communication Types | |
1 | Defining Statistics | |
1 | Defining Colors | |
2 | Maintaining Inbound Communications | |
3 | Defining Document Types | It is recommended that you use Document Types and Documents instead of attachments in Oracle Utilities Work and Asset Management. |
