Maintaining Metered Service Points
The Metered Service Point portal is used to display and maintain metered service points.
Refer to About Metered Service Pointsfor more information.
You can access the portal from Menu, select Digital Asset Management, then select Metered Service Point. You are brought to a query portal with options for searching for a specific record. Once a metered service point has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Metered Service Point: This zone displays basic information for this metered service point.
Service Point Attachments: This zone lists attachments associated with the metered service point.
Metered Services: This zone lists metered services associated with the metered service point.
Device Locations: This zone lists device locations associated with the metered service point.
SP Network Locations: This zone lists all network locations linked to any facility associated with the metered service point.
SP Business Flags: This zone lists the 25 most recent business flags associated with the metered service point.
