Maintaining Warranties
The Warranty portal is used to display and maintain a warranty record.
You can access the portal from Menu, select Asset Management, and then select Warranty. You are brought to a query portal with options for searching for a specific warranty. Once a warranty has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Warranty: This zone lists information about the warranty and associated asset.
  • Attachments: This zone enables users to manage all types of attachments for the warranty record.
  • Warranty - Notes: This zone displays notes associated with the warranty.
