Integration with BI Publisher
Your DBMS, your product, and BI Publisher can work together to produce reports. You may choose to use a different reporting tool, but this may not be a trivial effort. This section provides high-level information about some of the business requirements that are being solved with the reporting solution.
Multi-Language and Localization Support
The integration supports a multi-language implementation and supports different localization settings.:
  • All labels, headings and messages are defined using field and message meta-data in the application, which support multiple languages.
  • The appropriate font, size, and layout are based on the requested report and the user's language.
  • Dates and numbers are formatted as per the user's display profile.
  • Currency based numbers are formatted as per the currency definition from the product
