Defining Employee Types
The Employee Type portal is used to display and maintain employee types.
You can access the portal from Admin, select E, then select Employee Type.
  • Employee Type List: This zone lists all employee type records. Broadcast a record to display the details of the selected record.
  • Employee Type: This zone provides information about the selected employee type.
