Function - Send Fields
Use this page to add or update the fields sent to the service. Open this page using
and then navigate to the Send Fields tab.Note:
Displaying a specific field. Rather than scrolling through
each field, you can navigate to a field by clicking on the respective
node in the tree on the Main tab. Also note, you can use the Alt+right
arrow and Alt+left arrow accelerator keys to quickly display the next
and previous entry in the scroll.
You're defining the service's input fields. On this
tab, you define which fields are populated in the XML document that
is sent to the service. Essentially, these are the service's input
fields.
Description of Page
Use Sequence to define the order of the Send Fields.
Enter a unique Function Field Name and Description for each field sent to the application service. Feel free to enter Comments to describe how the field is used by the service.
Use Field Value Source to define the source of the field value in the XML document sent to the service:
- If the field's value is the same every time the function is invoked, select Defined On The Function. Fields of this type typically are used to support "hard-coded" input values (so that the scriptwriter doesn't have to populate the field every time they invoke the function). Enter the "hard-coded" Field Value in the adjacent field.
- If the field's value is supplied by the script, select Supplied By The Invoker. For example, if the function retrieves an account's customer class, the script would need to supply the value of the account ID (because a different account ID is passed each time the function is invoked). Turn on Required if the invoker must supply the field's value (it's possible to have optional input fields).
Regardless of the Field Value Source, use XML Population Logic to define the XPath expression used to populate the field's value in the XML document sent to the service.
