CMA Accelerator Load (K1-CMA-LOAD)
The K1-CMA-LOAD Infrastructure Process Type supports importing of an exported CMA file.
K1-CMA-LOAD is based on K1-CMAMigrationProcessType Infrastructure Process Type BO and uses the K1-CMAMigration as the Infrastructure Process BO.
The CMA Accelerator Load process type includes load an exported CMA and to run all the batch processes that are a part of the CMA import.
This process type does not include a step for a manual user review. It is assumed that when loading an accelerator, there shouldn’t be anything to review and the new configuration content is expected to be new for the most part or OK to override existing configuration.
Using the CMA Accelerator Load Infrastructure Process Type
In order to import a CMA export file (e.g. an accelerator), you need to:
Upload the file to the system designated storage location for CMA uploads. The location is configured on the CMA Master Configuration entry and is automatically defaulted to an Oracle Cloud Object Storage location during the system installation process.
Create a new infrastructure process with the K1-CMA-LOAD Infrastructure Process Type and provide the following additional details:
Name.
The Process Steps list is for reference only.
Export filename: specify the CMA export file name that was uploaded to the system. You should specify the full name including the file extension name.
User Review Needed: select “Yes” only if you are expecting the CMA file to include data that already exists in the system and need to be reviewed before changes are applied.
Default Status For Add, Default Status For Update are relevant in case you selected to have a user review. In this case define the default status of migration data items when imported into the target environment.
Once the process is saved, you can start it by selecting the Start action.
