Maintaining Other Direct Charges
The Other Direct Charges portal is used to display and maintain an other direct charge record.
Refer to About Timesheets for more information.
You can access the portal from Menu, select Work Management, then select Other Direct Charge. You are brought to a query portal with options for searching for a specific other direct charge. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
- Other Direct Charges: This zone displays information about other direct charges including an other direct charges details summary.
 - Other Direct Charges Detail Quick Add: This zone enables a user to quickly enter other direct charge details.
 - Other Direct Charges Details: This zone displays other direct charge detail information.
The following zones may appear as part of the portal's Log tab page:
- Other Direct Charges Log: This zone displays log details for the other direct charges record.
 - Approval Request History: This zone displays approval service histories for the other direct charge record.
