Defining Property Units
The Property Unit portal is used to display and maintain property units.
Refer to Understanding Construction Work for more information.
You can access the portal from Admin, select Financial, then select Property Unit.
- Property Unit List: This zone lists all property unit records. Broadcast a record to display the details of the selected record.
- Property Unit: This zone provides information about the selected property unit.
