Configuring VEE Groups
This portal is used to display and maintain a VEE Group.
You can access the portal by selecting Admin, then VEE, then VEE Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • VEE Group: Defines basic information about VEE group
  • VEE Rules List: lists the VEE Rules belonging to the group
  • Referencing VEE Rules List: lists the VEE Rules that reference the group
  • Referencing VEE Group Factors List: lists the VEE group factors that reference the group
  • Referencing Measuring Component Type List: lists the measuring component types that reference the group
  • Referencing Measuring Component List: lists the measuring components that reference the group
Note: VEE rules are not used with Oracle Utilities Digital Asset Cloud Service and Digital Asset Management, but a at least one VEE Group must be created as it is required when configuring measuring components and measuring compoment types. Ta single "empty" VEE group (a VEE group with no VEE rules).
