Maintaining Device Locations
The Device Location portal is used to display and maintain device locations.
Refer to About Device Locations for more information.
You can access the portal from Menu, select Digital Asset Management, then select Device Location. You are brought to a query portal with options for searching for a specific record. Once a device location has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Device Location: This zone displays location information for this device location record.
  • Customer Unavailability: This zone lists periods of time during which one more controllable devices are unavailable to participate in program events. Click Add to define a new unavailability period for a controllable device at this location. To edit an existing unavailability period for a controllable device at this location, select the period from the list and click Edit. To cancel an existing unavailability period for a controllable device at this location, select the period from the list and click Cancel.
