Reference Summary Zone
This zone presents a graph that illustrates the number of objects referencing the current project and sub-projects. The references for each object are categorized into three groups based on their respective business object lifecycle stages.
Activities
Activities refer to both Regular Work Activities and Construction Work Activities that are associated with the current project and sub-projects.
Regular Work Activity Initial Planning
Active Pending Approval, Approved, Rejected, Active, In Progress, Sent, In Progress (External), Finished, Completion Error
Final Completed, Canceled
Construction Work Activity Initial Planning
Final Closed, Cancel
Other Direct Charges (ODC)
Other Direct Charges refers to ODC Detail (Equipment and Other Resource) records that are associated with the current project and sub-projects.
Other Direct Charges EquipmentOther Direct Charges Other Resource Initial Planning
Active None
Final Posted, Canceled
Permits
Permits refer to both permits associated with the current project and permits for activities associated with the current project and sub-projects.
Reference Object Category Statuses
Internal Permit
External Permit
Initial Planning
Active Pending Approval, Rejected, Approved, Suspended, Active
Final Expired, Closed, Canceled
Purchase Orders
Purchase Orders refer to the purchase order lines associated with the current project and sub-projects.
Purchase Order Line (Craft, Equipment, Other Resource and Stock Item) Initial Created
Active Ready for Revision, Revised, Approved, Issued
Final Canceled, Closed
Purchase Requisitions
Purchase Requisitions refer to the purchase requisition lines associated with the current project and sub-projects.
Purchase Requisition Line (Craft, Equipment, Other Resource and Stock Item) Initial Created
Active Approved
Final Canceled, PO Processed, Blanket Contract Processed, Sent to External System
Timesheets
Timesheets refer to the Timesheet Detail records associated with the current project and sub-projects.
Timesheet Detail Initial Created
Active None
Work Designs
Work Designs refer to both Work Designs and Template Construction Work Orders that are associated with the current project and sub-projects.
Work Design Initial Created
Active Pending Approval, Approved, Rejected, Work Generated
Template Construction Work Order Initial Created
Active Active
Final Inactive
Work Orders
Work Orders refer to both Regular Work Orders and Construction Work Orders that are associated with the current project and sub-projects.
Regular Work Order Initial Planning
Active Pending Approval, Approved, Active, Reopened, Rejected
Final Completed, Closed, Canceled
Construction Work Order Initial Planning
Active Pending Approval, Approved, Active, Rejected
