Parameter | com.oracle.ouaf.batch.scriptDir |
Description | The base directory in which the scripts have to be placed for the generic infrastructure job to execute them. |
Ordinality | Optional |
Valid Values | Directory path. |
Source | Defaulted by configureEnv. |
Applicability | Background Processing |
Example: | com.oracle.ouaf.batch.scriptDir=$SPLEBASE/scripts/generic/batch/ exposed/$OWNER $OWNER would be the owner flag of the batch control thereby allowing restrictions on which scripts might be executed. Additional owners can be provided access by creating symbolic links in those owners’ directories. |
Parameter | com.ouaf.batch.disableAutoFlush |
Description | Disables the auto flushing of batch L2 cache. If this value is set to true, the L2 cache auto flush will be disabled. |
Ordinality | Mandatory |
Valid Values | [true|false] |
Source | Generated by template. Use Configuring Batch Using Bedit to implement a different value. |
Applicability | Business Application Server |
Example: | com.ouaf.batch.disableAutoFlush=true |
Parameter | com.ouaf.batch.flushIntervalInSeconds |
Description | Sets the time interval between batch L2 cache auto flushes. The time interval should be specified in seconds. |
Valid Values | Value in seconds. Default is 60. |
Example: | com.ouaf.batch.flushIntervalInSeconds=90 |
Parameter | com.ouaf.batch.jvmoptions |
Description | Custom JVM Options for threadpool. Note: This setting can be overridden using the -z option on the threadpoolworker.sh - Manage Threadpools command line. |
Valid Values | Valid JVM Options for the Java version used |
Source | Maintained by product templates. Use Configuring Batch Using Bedit to implement a different value. |
Example: | com.ouaf.batch.jvmoptions=-Xms1024k -Xmx2048k -XX:MaxPermSize=512m |
Parameter | com.splwg.grid.executionMode |
Description | Execution Mode used by this threadpool. Note: This setting can be overridden using the -e option on the threadpoolworker.sh - Manage Threadpools command line. |
Valid Values | [CLUSTERED] |
Source | Maintained by product templates. |
Example: | com.splwg.grid.executionMode=CLUSTERED |
Parameter | com.splwg.grid.distThreadPool.threads |
Description | Maximum number of threads for a particular threadpool. The format of the setting is: com.splwg.grid.distThreadPool.threads.<poolname>=<limit> where: <poolname> is the Name of the threadpool, <limit> is the thread limit supported by each instance of the threadpool. Note: This setting can be overridden using the -p option on the threadpoolworker.sh - Manage Threadpools command line. |
Valid Values | Threadpool names and limit must be valid. |
Example: | com.splwg.grid.distThreadPool.threads.DEFAULT=5 |
Parameter | com.splwg.batch.scheduler.daemon |
Description | Configures whether the threadpool should execute the online scheduler daemon. The online scheduler daemon checks that the Batch Submission transaction and initiates execution of pending batch jobs. Note: This setting can be overridden using the -d option on the threadpoolworker.sh - Manage Threadpools command line. Note: This setting should only be set to true in non-production environment where online submission is enabled. Note: In any non-production environment that uses online submission; one threadpoool should have this setting enabled. Typically, this is the DEFAULT threadpool but can be any other threadpool. |
Example: | com.splwg.batch.scheduler.daemon=false |
Parameter | jmx.remote.x.access.file |
Description | Sets relative location of JMX access control file holding the valid user. Refer to JMX Security for more details. |
Valid Values | Relative location of file from $SPLEBASE. Defaults to scripts/ouaf.jmx.access.file. |
Source | Value inherited from templates. Use Implementing Custom Templates to set this value to the desired location and file, if desired. |
Applicability | Web Application Server, Business Application Server. |
Example: | jmx.remote.x.access.file=scripts/ouaf.jmx.access.file |
Parameter | jmx.remote.x.password.file |
Description | Sets relative location of JMX password file holding the valid passwords for jmx.remote.x.access.file. Refer to JMX Security for more details. |
Valid Values | Relative location of file from $SPLEBASE. Defaults to scripts/ouaf.jmx.password.file |
Example: | jmx.remote.x.password.file=scripts/ouaf.jmx.password.file |
Parameter | oracle.ouaf.jmx.remote.maxPortsToTry |
Description | Number of ports to try starting from either oracle.ouaf.jmx.remote.startPort - Override Batch JMX Port or spl.runtime.management.rmi.port - JMX Port. If oracle.ouaf.jmx.remote.startPort - Override Batch JMX Port is not specified, the property spl.runtime.management.rmi.port - JMX Port is used that as the starting port. If neither property is defined or the maximum number of ports to try has been reached, an exception will be thrown that will prevent the system from starting. |
Valid Values | Number. Default: 200 |
Source | Set by BATCH_RMI_PORT - RMI Port for Batch. Use Configuring Batch Using Bedit to implement a different value. |
Example: | oracle.ouaf.jmx.remote.maxPortsToTry=100 |
Parameter | oracle.ouaf.jmx.remote.startPort |
Description | Alternative Port number allocated for Batch JMX Reference. This value is typically the same as spl.runtime.management.rmi.port - JMX Port. But may be set to the Coherence JMX port if Coherence based JMX is used on a different port. |
Valid Values | Valid JMX Port |
Example: | oracle.ouaf.jmx.remote.startPort=6510 |
Parameter | ouaf.batch.onlineLogDir |
Description | Sets the location of output from online batch submission and batch scheduler integration. If this property is set, batch logs will be accessible through the Batch Run Tree (application UI). Otherwise, the batch logs download link in the application will be disabled. |
Valid Values | Valid location. Defaults to: $SPLOUTPUT |
Source | Value inherited from BATCH_ONLINE_LOG_DIR from ENVIRON.INI. |
Example: | ouaf.batch.onlineLogDir=/tmp |
Parameter | ouaf.batch.onlineLogDir.retain |
Description | Sets the total number of log files that are to be stored for each batch code and thread number. The log files for the particular batch code and thread number will be deleted except for the latest number of logs specified. |
Valid Values | Number. |
Example: | ouaf.batch.onlineLogDir.retain=3 The above example will keep the last three logs and delete the rest |
Parameter | spl.runtime.batch.disableDeferredKeyInserts |
Description | Whether the deferring of key insert in batches should be disabled or not. Enables (false) or disables (true) deferred Key Inserts. The default is to use deferred inserts. However, if an aggressive key insert is desired in batches, a value of true should be used. Note: This setting is used by particular base batch jobs. Refer to the online documentation for individual batch jobs for more information. |
Example: | spl.runtime.batch.disableDeferredKeyInserts=false |
Parameter | spl.runtime.batch.L2CacheMode |
Description | Defines the 2nd-level cache mode for threads in threadpool. Valid values are READ_ONLY (default), READ_WRITE or OFF. READ_ONLY is for performance as it loads the configuration entities into the 2nd-level (JVM-level) cache and accesses them from there only. In READ_ONLY mode, the cached entities may not be updated. READ_WRITE also loads them into the L2 cache, but they can be updated. The drawback is that an update of a cached entity hits both the database and cache as it gets updated in both places. In OFF mode the 2nd-level cache is completely disabled. Some jobs, for example LDAP import (F1-LDAP), need to update some of these entities (for example, User), so it requires the L2 cache to be either OFF or READ_WRITE. The choice between OFF and READ_WRITE depends on requirement; the effect is the same. Note: This setting can be overridden using the -l2 option on the threadpoolworker.sh - Manage Threadpools command line. |
Valid Values | [READ_ONLY|READ_WRITE|OFF] |
Source | Maintained by product templates for threadpoolworker. Use Configuring Batch Using Bedit to implement a different value. |
Example: | spl.runtime.batch.L2CacheMode=READ_ONLY |
Parameter | spl.runtime.management.connector.url.default |
Description | JMX URL for Batch JMX interface. Note: This URL is generated and should not be altered. |
Valid Values | Valid JMX URL |
Source | Generated by template |
Example: | spl.runtime.management.connector.url.default= service:jmx:rmi:///jndi/rmi://{host}:{port} /oracle/ouaf/batchConnector |
Parameter | spl.runtime.management.rmi.port |
Description | Port number allocated for Batch JMX Reference. Note: This setting can be overridden using the -i option on the threadpoolworker.sh - Manage Threadpools command line. |
Example: | spl.runtime.management.rmi.port=1001 |
Parameter | spl.runtime.options.isDevelopmentMode |
Description | Enables or disables Development Mode for the product. Development mode disables and enables key features within the architecture to allow the Oracle Utilities SDK to be used optimally. The following settings are affected by this parameter: • Caching is disabled at all layers of the architecture. This can be renabled manually. • Screen Preloading is disabled. This can be renabled manually. • Compression is disabled at all layers of the architecture. This can be renabled manually. • The product is set to expanded mode to allow developers access to individual JEE objects rather than using WAR/EAR files. It is highly recommended that this setting should be set to false in production environments. This setting is only set to true where the Oracle Utilities SDK is used directly. |
Source | Derived from WEB_ISDEVELOPMENT parameter from ENVIRON.INI. |
Applicability | Web Application Server, Business Application Server, Inbound Web Services. |
Example: | spl.runtime.options.isDevelopmentMode=false |
Parameter | tangosol.coherence.distributed.localstorage |
Description | Specifies whether this member of the DistributedCache service enables local storage. Note: This setting is used by the Oracle Coherence DistributedCache Service. |
Example: | tangosol.coherence.localport.adjust=true |
Parameter | tangosol.coherence.distributed.threads |
Description | Specifies the number of daemon threads used by the distributed cache service. Note: This setting is used by the Oracle Coherence DistributedCache Service. |
Valid Values | Valid thread numbers. Default: 0 |
Example: | tangosol.coherence.distributed.threads=4 |
Parameter | tangosol.coherence.invocation.threads |
Description | Specifies the number of daemon threads to be used by the invocation service. If zero, all relevant tasks are performed on the service thread. Note: This setting is used by the Oracle Coherence InvocationService. |
Valid Values | Valid thread numbers. Default:0 |
Source | Generated by template (wka only). Use Configuring Batch Using Bedit to implement a different value. |
Example: | tangosol.coherence.invocation.threads=4 |
Parameter | tangosol.coherence.localhost |
Description | Host name for local host for Unicast address. Note: This setting applies to unicast or well known address implementations. |
Valid Values | Valid host name defined in hosts file and/or DNS. |
Example: | tangosol.coherence.localhost=myserver.example.com |
Parameter | tangosol.coherence.localport |
Description | Port number for local host for Unicast address. Note: This setting applies to unicast or well known address implementations. Note: This setting is used by the Oracle Coherence unicast-listener. |
Valid Values | Valid port number. |
Example: | tangosol.coherence.localport=6570 |
Parameter | tangosol.coherence.localport.adjust |
Description | Specifies whether the unicast port is automatically incremented if the specified port cannot be bound to because it is in use. Note: This setting applies to unicast or well known address implementations. Note: This setting is used by the Oracle Coherence unicast-listener. |
Parameter | tangosol.coherence.role |
Description | This contains the name of the member role. This name allows an application to organize members into specialized roles, such as cache servers and cache clients. The name is also useful for displaying management information (for example, JMX) and interpreting log entries. Note: This setting is used by the Oracle Coherence member-identity. |
Valid Values | Role Name |
Example: | tangosol.coherence.role=OUAF_Base_TPW |
