Defining Preventive Maintenance Calendar
The Preventive Maintenance Calendar portal is used to display and maintain preventive maintenance calendars.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Calendar.
Maintenance Calendar List: This zone lists all maintenance calendar records. Broadcast a record to display the details of the selected record.
Maintenance Calendar: This zone provides information about the selected maintenance calendar.
