Installation Types
The first step in the installation procedure is to determine the installation type that meets your business requirements. The following are the possible installation types:
• Initial Installation: Installing Oracle Utilities Work and Asset Management as a clean/new install - a base installation, typically used for a production environment
• Upgrade Installation: An upgrade installation from V2.3.0.0.0 or V2.4.0.0.0 to V2.4.0.1.1
• Demo Installation: A base installation with pre-populated demo data, typically used for demonstration or training purposes.
This installation type is applicable when installing Oracle Utilities Work and Asset Management for the first time. Each of the following components should be installed during an initial installation:
• Database components
Refer to the “Initial Install” section of the Oracle Utilities Work and Asset Management Database Administrator’s Guide for more information.
• Application components
• Oracle Utilities Application Framework Application
• Oracle Utilities Work and Asset Management Application
• Oracle Utilities Work and Asset Management Reports
• Oracle Utilities Work and Asset Management ESRI Integration
For detailed steps on installing each of the above components, refer to the
Installing Oracle Utilities Work and Asset Management - Initial Installation section.
This installation type is applicable when upgrading Oracle Utilities Work and Asset Management from V2.3.0.0.0 or V2.4.0.0.0 to V2.4.0.1.1. Each of the following components should be installed during an upgrade installation:
• Database components:
Refer to the “Upgrade Install” section of the Oracle Utilities Work and Asset Management Database Administrator’s Guide for more information.
• Application components:
Upgrading Oracle Utilities Work and Asset Management section.
Demo Installation
This installation type is applicable when installing a demo application of Oracle Utilities Work and Asset Management for demonstration or training purposes. For a demo install, you must install all of the following components:
• Demo Database components:
Refer to the “Demo Install” section of the Oracle Utilities Work and Asset Management Database Administrator’s Guide for more information.
• Oracle Utilities Application Framework application
• Oracle Utilities Work and Asset Management application
Refer to the
Installing Oracle Utilities Work and Asset Management - Demo Installation section for the steps involved in installing each of the above components.
Package Contents
The following documentation and installation packages are part of the product package.
Documentation
Installation Guides
• Oracle Utilities Work and Asset Management Release Notes
• Oracle Utilities Work and Asset Management Quick Install Guide
• Oracle Utilities Work and Asset Management Installation Guide
• Oracle Utilities Work and Asset Management Database Administrator’s Guide
• Oracle Utilities Work and Asset Management Licensing Information User Manual
User Guides
• Oracle Utilities Work and Asset Management and Oracle Utilities Operational Device Management Business User’s Guide
• Oracle Utilities Work and Asset Management and Oracle Utilities Operational Device Management Administrative User’s Guide
Supplemental Documents
• Server Administration Guide
• Security Guide
Installation Packages
• Oracle Utilities Work and Asset Management V2.4.0.1.1 Multiplatform
• Oracle Utilities Work and Asset Management V2.4.0.1.1 Oracle Database Multiplatform
• Oracle Utilities Application Framework V4.5.0.1.1 Multiplatform
• Oracle Utilities Work and Asset Management V2.4.0.1.1 Reports
• Oracle Utilities Work and Asset Management V2.4.0.1.1 ESRI Integration
