Importing Security Configuration from an External Source
The product provides support for importing security information from an external source:
  • If your organization uses Lightweight Directory Access Protocol (LDAP), you can import your existing LDAP users and groups into the system. Once imported, all user and group functions are available. You can import a user group, or a single user. You can resynchronize your LDAP users and groups at any time.
    Fastpath: For more information refer to LDAP Integration.
  • The system provides an integration with Oracle Identity Manager. When a user is created in the identity manager product, its information can automatically be interfaced to the product. Once the user is successfully created in the system, all functions are available.
    Fastpath: For more information refer to Oracle Identity Manager Integration.
