Defining Market Configurations
Each market configuration is used to define one or more options for a given type of configuration (based on a delivered business object).
The product defines a generic set of portals, described here, that may be used to define any type of market configuration. However, it may be that your implementation includes more specific configuration portals for certain types of market configurations.
Open this page using
You are brought to the Market Configuration Query where you need to search for the market configuration (i.e., its business object).
Once you have found the appropriate market configuration, select the value and you are brought to a standard All-in-One portal that lists the existing values for the market configuration. The standard actions for an All-in-One portal are available here.
