Introducing Health Check Conditions
If your implementation would like to check a condition for system health that is not already provided by your product, here are the steps required:
  • Define a new value in the Health Component Type lookup (HEALTH_​COMP_​FLG).
  • Provide a new algorithm type, plug-in script and algorithm for the Health Check system event that checks the condition that you wish to check. Refer to the Service Health Check topic for the information that each algorithm should be supplying for the condition. Note that if you follow the pattern of the system delivered Batch Control - Level of Service algorithm, your algorithm may be designed to check conditions across many records of the same type and gather all the results.
  • Plug this new algorithm into the Installation Options - Algorithms collection using the Health Check system event.
