Maintaining Other Direct Charges
The Other Direct Charges portal is used to display and maintain an other direct charge record.
You can access the portal from Menu, select Work Management, then select Other Direct Charge. You are brought to a query portal with options for searching for a specific other direct charge. Once a record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • Other Direct Charges: This zone displays information about other direct charges including an other direct charges details summary.
  • Other Direct Charges Detail Quick Add: This zone enables a user to quickly enter other direct charge details.
  • Other Direct Charges Details: This zone displays other direct charge detail information.
