Oracle Utilities Work and Asset Management Enhancements
This section describes new and enhanced features in this release of Oracle Utilities Work and Asset Management.
The release includes:
Note: The Steps To Enable sections provide guidelines for enabling each feature, where applicable.
User Interface Enhancements
This section describes the new and enhanced user interface features in this release, including:
Activity Portal - Create Service Histories Against Only the Activity
The Service History Types zone in the Completion tab of the Work Activity portal lists valid service history types and condition assessment service history types associated to the assessment class for the asset in context or planned service history types for the activity. In this release, this zone allows you to create a service history against only an activity by clicking Add prior to broadcasting an asset row. Previously, you needed to broadcast an asset to view the service history types and you could not create a service history unless Asset or Asset Location was populated.
Additionally, the Asset Service History zone is renamed to Asset Service Histories and the application only displays this zone after you broadcast an asset or asset location. The Activity Service History zone is also changed to Activity Service Histories and is always displayed regardless of if the activity has an asset or not. Previously, the application always displayed the Asset Service History zone and the Activity Service History zone was only displayed if the activity did not have an asset.
Steps to Enable
No steps are required to enable this feature.
Tips and Considerations
If an activity does not have an asset, the existing Default Location From Asset or Activity on Service History (W1-DEFLOCASH) algorithm copies the asset location and work location to the service history. You can deactivate this algorithm by doing the following:
1. Select Admin, System, and Business Object.
2. Find the General Service History (W1-ServiceHistoryWAM) business object.
3. Add the Inactive Algorithm option type and set the following configuration:
• Option Type: Inactive Algorithm
• Sequence: 10
• Option Value: W1-DEFLOCASH
4. Save the changes.
5. Find the Questionnaire Service History (W1-QuestionnaireSvcHist) business object.
6. Add the Inactive Algorithm option type and set the following configuration:
• Sequence: 10
7. Save the changes.
GIS Map Viewer - Asset Characteristic Filter, Clear List Shortcut, and Descriptive Filter Tooltip
The GIS Map Viewer allows you to view assets and work information based on geospatial mapping. In the Asset tab, you can now filter assets based on asset characteristics. In the Work tab, the number of entries in the list are displayed together with the number of filters selected. In both these tabs, the filter tooltips show drop-down filter descriptions instead of codes. The GIS Map Viewer also provides a Clear List shortcut that quickly removes all selected assets from the list.
Steps to Enable
GIS Map Viewer - Enhanced User Experience and Additional Functions
The new GIS Map Viewer brings a complete Redwood user experience, the existing Legacy Map Viewer features, and the following additional functions:
• Streamlined User Interface
• Collapsible Panels
• Common Tool Selection
• Delete Option for Saved Asset Filters
• Individually Displayed Item Details
• Export to File Options - Preferred Format and Layout
In this release, the GIS Map Viewer uses the latest ESRI ArcGIS JavaScript API and Oracle JET. Previously, the map viewer was built on the ArcGIS JavaScript version 3 API.
Steps to Enable
Access to the new GIS Map Viewer is via the W1GISMAP application service.
The application automatically gives access to the new GIS Map Viewer to users with access to the Legacy GIS Map Viewer.
Saved asset filters are accessible in the enhanced GIS Map Viewer.
The recommended system requirements for the enhanced GIS Map Viewer are as follows:
• WebGL-enabled Browsers
• System Memory
• Desktop Browsers: 8GB
• Mobile Devices: 4GB
Control Ability of Employees to Approve Their Own Timesheet
A new parameter Allow Employees To Approve Own Timesheet is introduced in the Work Management Master Configuration. If the value is blank or No, employees cannot approve their own Timesheet. If Yes, employees can approve their own Timesheet.
This gives you control over whether employees are allowed to approve their own timesheets even though they are approvers on the approval profile.
Steps to Enable
To enable this feature, set the Allow Employees To Approve Own Timesheet parameter in the Work Management Master Configuration according to your business rules.
This section describes the new and enhanced asset management features in this release, including:
Asset Type - Auto-Generated Asset or Badge Number
The new Automated Number zone in the Main tab of the Asset Type portal enables you to configure the asset type to automatically generate an asset number and/or badge number for a new asset. For auto-generated numbers, you can assign custom or calendar prefixes and set the length of the numbering sequence. Using a calendar prefix inserts the current year into the auto-generated number and the sequence number resets to zero at the beginning of each calendar year.
These fields facilitate the configuration of an asset type's auto-generated number settings:
• Asset Number
• Asset Number Generation
• Asset Number Prefix
• Asset Number Calendar Prefix
• Asset Number Sequence Length
• Badge Number
• Badge Number Generation
• Badge Number Prefix
• Badge Number Calendar Prefix
• Badge Number Sequence Length
Steps to Enable
Preventive Maintenance - Cycle Now - Access Security
The Cycle Now button in the Maintenance Trigger zone of the Maintenance tab in Asset portal enables any user to skip pre-configured rules for asset preventive maintenance and force the running of a preventive maintenance trigger to create a maintenance work order. The "W1-ASSET" application service for Asset MO now provides a "Maintenance Trigger Force Execution" access mode that limits the use of the Cycle Now button to user groups assigned with the new access mode.
This grants control to users that are only authorized to force preventive maintenance triggers of cycling assets.
Steps to Enable
Access Requirements
System administrators should grant "Maintenance Trigger Force Execution" access to the appropriate user group(s) in the "W1-ASSET" application service.
Asset Status - Auto-Transition from Planned to In Service
The Transition Planned Asset to In Service (W1PLANDSTRN) algorithm provides customers with the capability to automatically transition the status of new non-tracked, non-inventory assets to "In Service" from "Planned". Previously, only assets created through the ESRI GIS integration were given the option to automatically transition from the "Planned" to "In Service" status.
The algorithm is available in the Planned In/Out of Service Asset Root business object and its default setting is a "No" transition (meaning assets stay in planned status). You can automatically transition the asset status from "Planned" to "In Service" using the following parameters:
• Apply to all planned assets: Set to "Y" to transition all planned assets, regardless of the Apply to planned assets created in Construction Work Activity and Apply to planned assets created using the Generic Loader settings.
• Apply to planned assets created in Construction Work Activity: Set to "Y" to automatically transition all assets created through the Construction Work Activity portal.
• Apply to planned assets created using the Generic Loader: Set to "Y" to transition all assets created through the Online or Batch Loader.
Steps to Enable
Asset Location Type - Asset Location Attribute Types
The Asset Location Attribute Types field of the Asset Location Types portal enables you to store GIS-like attribute information.
As a result, you no longer need to create custom Asset Location business objects to store GIS-like attributes.
Steps to Enable
Capital Plant Work - Manual Creation/Update of Fixed Assets
The Update Fixed Asset Information (W1UF) access mode enables you to manually create or update a fixed asset without a construction work activity or compatible unit. The Send Fixed Asset Information (W1SF) access mode allows you to send the created or updated fixed asset information to an external system. Previously, the application only supported the creation or update of fixed assets via Construction Work Activity or Received/Accepted Capital Spare Items.
Steps to Enable
System administrators should grant Update Fixed Asset Information (W1UF) and Send Fixed Asset Information (W1SF) access to the appropriate user group(s) in the application services of Asset business objects.
Engineering Specification Attributes - Configurable by Asset Type
You can now configure asset attributes by asset type on Engineering Specifications. Previously, new Engineering Specification business objects were needed and created to configure asset attributes on asset types.
You do not have to create Engineering Specification business objects to capture different asset attributes.
Steps to Enable
"In Receipt" Tracked Asset - Bypass "In Store" Status
You can move "Rejected" or "In Repair" tracked assets to the "In Receipt" status. This bypasses the "In Store" status. Previously, when "In Receipt" tracked assets encountered failures, the application moved these assets to the "Rejected" or "In Repair" status only and the assets were returned to the vendor.
This reduces implementation costs.
Steps to Enable
Organization and Asset Location Portal - Improved Tree Views
The tree views of the Organization and Asset Location portals now display the entire organization and location structures respectively, and the direct parent/child hierarchy. Additionally, both tree views load more efficiently in this release. Previously, the Organization and Asset Location tree views only displayed direct hierarchy, which included its child organizations and locations.
Note: By default, the number of children for the auto-expansion parameter in the tree algorithm is set to 50. The tree views automatically display the organization and location children if the number of children does not exceed 50. In case the number of children exceeds 50, you must manually expand the tree views to display the children information.
Steps to Enable
Asset 360
The 360 tab on the Asset portal serves as a comprehensive summary hub that provides a centralized view of all relevant information about a specific asset. By consolidating data and insights in one location, it offers a clearer understanding of the events and actions associated with that asset. This streamlined approach eliminates the need to navigate across multiple portals or click through various links to gather similar information, facilitating more efficient decision-making and management.
The following zones are available in the 360 tab:
• Asset: Displays common actions that can be taken for the asset, along with key asset and location information. Additionally, it provides insights related to Asset Criticality and Asset Risk.
• Asset Availability, MTBF, and MTTR information are insights displayed on this zone. Asset Availability displays the percentage the asset has been operational (up and running) during the Inservice/Installed life of the asset. These metrics for Asset Availability, MTBF, and MTTR are calculated using both downtime and failure service history data. For these calculations, both the downtime and failure service histories must be linked to the same activity and the activity must be in either a Completed or Closed status.
Configuration is required to display the Asset Availability, MTBF, and MTTR information on the Asset zone.
• Insights: Displays visual insights for Condition Rating, Confidence Rating, Maintenance Trigger, Asset List Maintenance Trigger, and Warranty. Each insight includes a badge, and all except Condition Rating show a list of common actions.
• Current Activities: Displays the number of current (non-final) activities for the asset, along with up to five of these activities ordered by total risk priority (highest first) and required by/activation date (oldest first).
• Attachments: Displays an image of the asset along with up to eight attachments.
• Asset Cost Breakdown by Service Class: Displays the total lifetime cost of the asset, as well as the cost per service class.
• Asset Type Cost Breakdown by Service Class: Displays the total lifetime cost of the asset type, as well as the cost per service class.
• History: Displays the asset’s activities, measurements, and service histories. Only eight records are shown at a time, with pagination enabled to view additional records. In addition, this zone displays all permits directly related to the asset and permits related to activities that involve the asset.
The Asset 360 tab is the default tab for the Asset portal once an asset is selected. You are given an option to opt out of the 360 default tab and make the Main tab the default on a system-wide basis or at the user-level.
Steps to Enable
To enable this feature, refer to the Asset 360 Configuration and Setting the Asset Portal Default Tab sections of the Administrative User Guide for more information.
Asset Characteristic Search and Asset Attributes - Predefined Characteristic Type
Asset search provides the capability to select a Predefined Characteristic Type query filter from options that are sorted alphabetically by description. The Asset Attributes zone also uses Predefined Characteristic Type, providing you a list of attributes during editing that are sorted and displayed alphabetically by description.
This enhances the user experience by displaying Predefined Characteristic Types drop-down values by description and in alphabetical order, making the selection in Asset Characteristic search and editing in Asset Attributes easier.
Steps to Enable
Asset Location - Detailed Description
The Detailed Description field (with a 4000 character limit) in the following Asset Location business objects enables you to provide a clearer and comprehensive asset location description:
• General Asset Location (W1-GeneralAssetLocation)
• Linear Asset Location (W1-LinearAssetLocation)
• Plant Asset Location (W1-PlantAssetLocation)
• Operational Device Asset Location (W1-AssetLocation)
Also, the Asset Location search now enables you to search records with detailed descriptions using the Description filter.
Steps to Enable
Asset Type - Asset and Engineering Specification Attributes - Sequence Number
You can now assign sequence numbers for valid attributes on an asset type for assets and specifications for that asset type. Those attributes on assets and specifications will be displayed in the order of the sequence numbers.
This gives you control of the order in which attributes are displayed.
Steps to Enable
Measurement - Reading Date/Time
Reading Date/Time now defaults to the current date/time to ensure Measurement records accurately reflect the date and time the measurement was taken. Previously, when a Measurement record was created, the Reading Date/Time defaulted to a blank field, requiring the date and time to be manually selected and usually defaulted to 12:00 AM. In situations where the default date and time were not revised, this made the record incorrect.
This ensures Measurement records accurately reflect the date and time when the measurement was taken.
Steps to Enable
Operational Device Management Asset Portal
This portal is a streamlined version of the Work and Asset Management asset portal and includes only the tabs relevant to Operational Device Management assets:
• Main
• Device
• Tree View
• Asset Disposition
• Log
This improves the user experience. It focuses you on only relevant Operational Device Management-related information.
Steps to Enable
Users must be granted "Inquire" access to the Operational Device Management Asset Portal (W1ODMAST) application service to use this feature.
The Operational Device Management Asset portal is secured by the Operational Device Management Asset Portal (W1ODMAST) application service. You must be granted Inquire access to view this page.
The following Operational Device Management asset business objects are impacted by this change:
• Operational Device Asset (W1-InOutSvcAsset)
• Operational Device Component (W1-InOutSvcComponent)
• Operational Device Tracked Asset (W1-TrackedAsset)
• Operational Device Tracked Component (W1-TrackedComponent)
To opt out of the Operational Device Management Asset portal and continue using the Work and Asset Management Asset Portal for Operational Device Management assets:
1. Navigate to the Operational Device Management business objects.
2. Add a higher sequence Portal Navigation Option and set the option value to the Asset Default Tab (w1astdfltTabMenu) navigation option.
Service History Comments
The character limit of the Service History Comments field is now 4000, addressing the need for more detailed record-keeping and overall usability. Previously, the character limit was 254. This update aligns with the requirements for improved documentation and operational efficiency.
This provides the capability for more detailed and comprehensive record-keeping.
Steps to Enable
Batch Processing Enhancements
This section describes the new and enhanced batch processing features in this release, including:
Generic Online/Batch Loader Attachment Location Validation
Currently, attachments are stored in the database along with its entire content in a CLOB field. This poses a problem for uploading and maintaining very large attachments, such as videos and so on. The Application Framework has been enhanced to store content of large files in Oracle Cloud Object Storage based on a configurable file size threshold (current default is 20MB), however the Loader can only process content in the database. A validation is put in place such that only attachments stored in the database can be referenced on an Online or Batch Loader Request Type. If your organization takes advantage of object storage and the .csv file you try to load is above the file size threshold, you need to split it into smaller files and upload those smaller files separately.
This provides validation upfront before you submit the batch job 'W1-GAUPL' and encounter errors if the actual attachment data is not stored in the database of the application because of its size.
Steps to Enable
Inventory Enhancements
This section describes the new and enhanced inventory features in this release, including:
Repair and Returned Tracked Assets - Average Unit Price Calculation
All items of the same stock item in a storeroom should be assigned an Average Unit Price (AUP). Unlike regular stock items, trackable stock items use asset disposition to track inventory quantity and the average unit price is captured on each asset. Repairable stock items can be assigned "Repaired Prices" when returned to the inventory. The assigned repaired price for the repaired item is used for financial transactions (like increase of inventory value) when a repaired asset is returned to a storeroom and impacts the average unit price of the stock item. Also, the AUP Contribution Amount on assets of that stock item in the storeroom gets updated to match the AUP and prevents the AUP from changing after assets are issued at a later time.
This accurately tracks inventory value for repaired and returned tracked assets.
Steps to Enable
Receiving Inventory (Regular Items) - Enhanced Multi-step Receive Process
The Accept on Receipt parameter of the Receiving Inventory process instructs the application whether to receive and accept the item at same time (set to Yes) or receive and accept the item separately (set to No and a multi-step receiving process occurs). For purchase orders with several line items, multi-step receiving is tedious to complete as it involves several mouse clicks and page loads. This release provides an "Accept All Pick List" option to reduce the completion steps of multi-step processing for regular inventory items. The option includes the Receive All and Accept Regular Inventory and Receive All and Accept Regular Inventory (Batch) links, which appear in the Additional Processes section of the receipt. The Receive All and Accept Regular Inventory (previously Receive and Accept All Regular Inventory) process fully receives and accepts all the regular inventory items but excludes those that are individually not selected. The Receive All and Accept Regular Inventory (Batch) process is recommended for receiving large numbers of purchase orders and is similar to the first process, but the difference is that the items are submitted automatically via a batch job.
Additionally, the Receipt portal provides a new Activity tab that displays the Purchase Order Line Activity zone. Previously, the zone appeared in the Main tab of the portal.
Note: The portal displays the "Accept All Pick List" option if the receipt has at least one regular inventory item that will go through the multi-step receiving process. Otherwise, the portal does not display the option and all regular inventory items are fully received and accepted.
Steps to Enable
The application only presents the "Accept All Pick List" if the receipt has at least one regular inventory item that will go through the multi-step receiving (the corresponding Accept on Receipt parameter is set to No). Otherwise, the application does not display the UI and fully receives and accepts all regular inventory items.
If needed, you can submit the Receive All and Accept Regular Inventory batch job in debug mode (trace output enabled). To turn on the batch debug mode, complete these steps:
1. Navigate to Feature Configuration.
2. Search for a "Batch Debug" feature type.
3. Edit the batch debug feature. If none, add a new feature, populate Feature Name and Description then set Feature Type to Batch Debug.
4. Add a Receive All and Accept Regular Inventory option type and set its value to Y.
5. Save the changes.
To turn off the batch debug mode:
1. Search and edit the batch debug feature.
2. Set the Receive All and Accept Regular Inventory option type to N.
Access Requirements
System administrators should grant user groups with the Execute access to the W1RCACAL application service in order to run the W1RCACAL batch control, which handles the receive and accept batch processing.
Receive All and Accept Items Links - Expanded for Non-Inventory Items Receiving
The Receive All and Accept Items (online and batch) links in the Additional Processes section of the Receipt portal can now process non-inventory items, such as direct purchase and expense at receipt. The Accept on Receipt parameter of the Receiving Inventory process instructs the application whether to receive and accept inventory and non-inventory items at same time (set to Yes) or receive and accept the items separately (set to No and a multi-step receiving process occurs). The Accept All Pick List option that reduces the completion steps of multi-step processing for regular inventory items now also applies to non-inventory items. Previously, only regular inventory items were processed by the Receive All and Accept Items links.
Steps to Enable
Purchase Order Search Filter is Available in the Return Search Portal
The Purchase Order search filter in the Return search portal has been improved to utilize the PO header search instead of the PO line search. This upgrade allows users to search for returns associated with the entire PO, eliminating the need to examine one PO line at a time.
Additionally, the Return search option has been added to the PO context menu, reducing clicks needed to access the Return search portal.
Steps to Enable
Physical Inventory Portal - Number of Selected and Discarded Items
The application now displays in the Physical Inventory Header zone the number of items selected by the system and the number of discarded items in the Items Summary zone. Previously, you could specify various criteria on a Physical Inventory Count Header and the system would select the stock items accordingly. You could also manually discard the items from being included in the actual count.
This provides high-level statistics information about a physical inventory.
Steps to Enable
Purchasing Enhancements
This section describes the new and enhanced purchasing-related features in this release, including:
Blanket Contract Used Amount - Additional Calculation Rules
The calculation rules for the Blanket Contract Used Amount now consider scenarios of unfulfilled orders or items received/accepted exceeding the original number of orders. The calculation rules take into account whether the blanket contract consists of a Blanket Purchase Agreement (contract with items) or Contract Purchase Agreement (contract without line items). For a blanket purchase agreement, the Blanket Contract Used Amount calculation rules only include purchase order line items that reference any of the blanket contract's line items. For a contract purchase agreement, the calculation rules include all of the purchase order's line items that reference the blanket contract. After determining the purchase order line items, these rules are applied to calculate the PO Line Contributed Amount (POLCA), which is summed up as the Blanket Contract Used Amount:
• If the purchase order line item's status is "Issued" and is fully received, then POLCA = (PO Line Quantity * PO Line Unit Price) - Total Returned for PO Line's Credit Amount
• If the status is "Issued", the purchase order line item is fully received, and there are more items received than order then POLCA = (Total Accept Quantity * PO Line Unit Price) - Total Returned for PO Line's Credit Amount
• If the status is "Completed", then POLCA = Sum of All Normal and Credit for Quantity Adjustment Invoice Lines for the PO Line
Previously, the calculation rules for the Blanket Contract Used Amount were as follows:
• Total Amount of All Issued Purchase Orders Against the Blanket Contract - Total Returned for Credit Amount Against the Purchase Orders
However, if the purchase order was completed but all the order was not fulfilled, the calculation rules did not adjust the Blanket Contract Used Amount to reflect the unfulfilled orders.
Steps to Enable
Unit Price - Extended Decimal Places
This release extends the decimal limit of the Unit Price field to seven places for purchase orders, purchase requisitions, and blanket contracts. Previously, the limit was two or three decimal places depending on the currency used.
This captures a more accurate unit price value.
Steps to Enable
Notes and Standard Notes are Copied Between Documents
When you create a Purchase Order or a Blanket Contract from a Purchase Requisition, notes and standard notes from the Purchase Requisition header and lines are copied onto the header and lines, respectively, of the Purchase Order or Blanket Contract.
This makes creating Purchase Orders or Blanket Contracts more efficient.
Steps to Enable
Notes and Standard Notes are Copied From Documents Created from a Blanket Contract
When you create a Purchase Requisition or a Purchase Order from a Blanket Contract, notes and standard notes from the Blanket Contract header and lines are copied onto the header and lines, respectively, of the Purchase Requisition or Purchase Order.
This makes creating Purchase Requisitions or Purchase Orders from Blanket Contracts more efficient.
Steps to Enable
Notes and Standard Notes are Copied to Revisions for Purchase Orders and Blanket Contracts
When you create a Purchase Order revision or a Blanket Contract revision, the notes and standard notes from the previous revision's header and lines are copied onto the header and lines, respectively, of the new revision.
This makes creating Purchase Order revisions and Blanket Contract revisions more efficient and avoids audit issues.
Steps to Enable
Credit Memo - Freight and Extra Costs Proration
Easily back out all the financial impact of the original invoice by creating a credit memo and specifying an amount for freight and extra cost on a credit memo invoice header. You can also choose to prorate the freight and extra cost to credit memo lines.
This allows you to credit back freight and extra cost when creating a credit memo.
Steps to Enable
Purchase Order - Revisions
Creating a new purchase order revision automatically carries over the attachments from the originating revision to the new revision.
This makes purchase order revisioning easier and more accurate.
Steps to Enable
Resource Management Enhancements
This section describes the new and enhanced resource management features in this release, including:
Timekeeper Portal - Employee List Sorted by Last Name Then First Name
The Employee zone of the Timekeeper portal now sorts and displays the Employee list by last name then by first name. Previously, the zone sorted records by Employee ID.
Steps to Enable
Work Planning and Crew-shift Schedule Queries - Materialized View Dependency Removed
The W1_PARENT_ORG_MT_VW materialized view is regularly refreshed in both staging and production environments using a DBMS scheduler batch job. However, this refresh process, which completely refreshes the data, is causing performance delays. To mitigate this issue, all crew shift schedules and work planning search queries that use the materialized view have been redesigned and no longer rely on this materialized view.
Rework work planning and crew shift schedule search queries to bypass the materialized view improves performance and reducing resource consumption.
Steps to Enable
Due to the redesign of the work planning and crew-shift schedule queries, the W1_PARENT_ORG_MT_VW materialized view is no longer needed and has been removed. Customers should review their custom code and remove any references to the W1_PARENT_ORG_MT_VW materialized view. Specific base package zones that have been impacted by this change include the following:
• Activity Information (W1-WPACTQ1)
• Activity Information (W1-SCHDLRQ4)
• Labor Requirement Information (W1-SCHDLRQ6)
• Previously Scheduled Unfinished Work (W1-SCHDLRQ2)
• Location Information (W1-SCHDLRQ5)
• Schedule (W1-SCHDLRQ1)
• Work Order Information (W1-SCHDLRQ3)
Timekeeper Search Restricted by Owning Organization
The all-in-one Timekeeper portal has been separated into a Search portal and a Maintenance portal. The Owning Organization field has also been added to the Timekeeper record. When the Owning Organization field on a Timekeeper record is specified, only users with that Owning Organization can search for, thus view and update that Timekeeper record.
Steps to Enable
New Timekeeper search portal along with a new application service 'W1TMKPRQ' is introduced. All users with access to the existing all-in-one portal for Timekeeper are automatically given access to the Timekeeper search portal through this application service.
Activity Resource Requirement - Expense Code - Application Security
On the Activity Resource Requirement's Quick Add and Activity Resource maintenance, you can modify the Expense Code value. However, when the resource type's Default Values to Activity flag is set to "Yes", the Expense Code should not be changed from the resource type's value. In this release, each of the Activity Resource Requirement business object's Application Services and the WAM_SERVICES user group includes the Override Expense Code access mode, preventing the Expense Code to be change to the resource type's value when the Default Values to Activity flag is set to "Yes".
Steps to Enable
Provide the required access before using the feature.
Access Requirements
System administrators should grant "W1OE- Override Expense Code" access to the appropriate user group(s) in the following application services:
• Equipment for Activity BO (W1-EQUIPMENTACTBOAS)
• Labor for Activity BO (W1-LABORACTBOAS)
• Material for Activity BO (W1-MATERIALACTBOAS)
• Miscellaneous Resource for Activity BO (W1-OTHERACTBOAS)
Construction Work Activity - Compatible Unit Deletion
You can now delete compatible units when a construction work activity is at an "Approved", "Active", "In Progress", "Sent", or "Sent In Progress" status. Planned assets existing under the deleted compatible unit will be deleted. Also, when the deleted compatible unit is the only contributor to an Activity Resource Requirement, the application cancels that activity resource requirement.
Previously, compatible units could only be deleted when the construction work activity was at a "Planning" status. Also, after the construction work activity had been approved and the compatible unit was not needed anymore or no work was carried out for the compatible unit, you could update the Actual/Completed Quantity to zero for the deleted compatible unit.
Steps to Enable
Work Management Enhancements
This section describes the new and enhanced work management features in this release, including:
Construction Work Activity - Outbound Configurations
The Maintain Work Order Activity (W1-WOACTAMSG) and Cancel Work Order Activity (W1-WOACTFMSG) outbound message types enable you to route construction work activities to an external system for scheduling and execution.
By setting configurations at each construction work activity type level, a construction work activity can be routed to an external system for scheduling and execution.
Steps to Enable
To enable this feature, complete these steps:
1. Add an external system.
2. Add the Maintain Work Order Activity (W1-WOACTAMSG) and Cancel Work Order Activity (W1-WOACTFMSG) outbound message types and corresponding message sender.
3. Update the Outbound Activity Information of the appropriate activity type.
• Use the external system setup in step 1.
• Use Maintain Work Order Activity (W1-WOACTAMSG) for Add and Update usage.
• Use Cancel Work Order Activity (W1-WOACTFMSG) for Cancel and Complete usage.
System administrators should grant access to the Construction Work Activity BO application service to any user that routes construction work activities to external systems.
Construction Work Activity and Construction Work Activity Type - Planned Service History Types
The Construction Work Activity portal enables you to maintain a construction work activity record. The new Planned Service History Type zone in the Main tab allows you to add a mandatory or optional planned service history type to the record. The Activity Type portal allows you to maintain activity types, which represent a broad range of activities like maintenance, repairs ,and inspections. The Activity Type zone in its Main tab enables you to define the main attributes of a planned service history. In this release, the application copies all planned service history types from the activity type to the created construction work activity record. If the activity is routed to an external system, the activity outbound details include the planned service history types.
Steps to Enable
Construction Work Order - Add Activities from Template Construction Work Order
You can now select template construction work activities from a template construction work order and add these work activities to an existing construction work order. You can perform this action by using the Add Activities from Template Construction Work Order option in the Activity Information zone of the Construction Work Order portal. Previously, a construction work order was only created from a complete copy of a template construction work order through the Create Construction Work Order button of the Template Construction Work Order portal.
Steps to Enable
Construction Work Activity Reconciliation - Customer-contributed Assets
This release enables the application to assign the estimated cost of a Compatible Unit as the default value of customer-contributed assets during the creation of a work activity reconciliation. Previously, you can only manually enter a customer-contributed asset value at the end of the construction work activity.
This provides default customer-contributed asset values at the end of construction work activities.
Steps to Enable
Template Construction Work Activities - Planned Service History Types, Duration, and Unit of Time
A template construction work activity now includes a Planned Service History Type, Duration, and Unit of Time. You can mark the planned service history type as "Optional" or "Required".
These align the elements of the template construction work activities with the regular template and work activities.
Steps to Enable
Construction Work Activity - Same Crew Applied to Dependent Activities
The Activity Dependency zone of the Construction Work Activity portal lists the active construction work activities that are dependent on the current construction work activity record. This zone provides the new resource option, Same (W1SM), which indicates that the crew or shift assigned to the activity must be the same as the crew or shift working on the dependent activity. Previously, the resource options provided by the zone were as follows and the crew or shift working on the activity had to be different from the dependent activity:
• Any (W1AN): No restriction on which crew or shift can perform the work.
• Separate (W1SP): The crew or shift assigned to the activity must be different from the crew or shift working on the dependent activity.
• Separate from All (W1SA): The crew or shift performing the job must be different from the crew or shift working on any activity in the entire dependency chain.
Steps to Enable
Construction Work Activity and Template Construction Work Activity - Backlog Groups
The Backlog Group fields in the Construction Work Activity and Template Construction Work Activity portals enable you to add backlog group information to construction activities and templates. Additionally, a construction work activity created using a template with a defined backlog group automatically inherits that group. Previously, backlog group information can only be added to a regular work order and work order template.
This provides consistency between the creation of regular and construction work activities.
Steps to Enable
Work Location - Service Area
The Work Location zone now includes a Service Area field, enabling you to define a logical boundary for your organization's service territory.
This enables you to assign the appropriate crew or shift to a work location.
Steps to Enable
Construction Work Activity - Mobile Interim Completion
The application can now process interim completion information sent by Oracle Field Service or an external system. The application keeps the construction work activity in its current "In Progress" state and processes the interim completion of other activities like asset installation/removal, service histories and measurements creation, and construction location update. When the application resends the activity to the crew, the activity details reflect all the work and interim completion for the activity. Previously, the mobile construction work activity completion service assumed a completed work activity when Oracle Field Service or the external system sent the activity information to the application.
Steps to Enable
Integration and Web Services
This section describes the new and enhanced inbound and outbound web services and integration features in this release, including:
Oracle Utilities Work and Asset Management-Oracle Fusion Cloud Project Management Integration
The integration between Oracle Utilities Work and Asset Management and Oracle Fusion Cloud Project Management enables you to:
• Synchronize projects between applications.
• Define projects in Oracle Fusion Cloud Project Management and push them to Oracle Utilities Work and Asset Management.
• Get construction or maintenance project updates from Oracle Fusion Cloud Project Management and send these Oracle Utilities Work and Asset Management.
• Push work activities from Oracle Utilities Work and Asset Management to Oracle Fusion Cloud Project Management as project tasks.
• Receive activity updates from Oracle Utilities Work and Asset Management as project tasks in Oracle Fusion Cloud Project Management.
Steps to Enable
To enable this feature, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Assets Configuration Guide for more information.
GIS Feature Classes Synchronization - Filter Statement Builder
The synchronization of GIS feature classes to Oracle Utilities Work and Asset Management could be defined through the Filter Statement Builder or the default "Skip" behavior. Previously, all GIS feature classes were synchronized to Oracle Utilities Work and Asset Management except those marked as "SKIP". With the Filter Statement Builder, you can synchronize GIS feature classes whose GIS field-value combination match that of the WAM Sync Mapping extendable lookup.
This provides flexibility in configuring GIS Field and GIS Value with various comparison operators and data types, which enables the generation and submission of a filter statement to retrieve a subset of records from GIS tables.
Steps to Enable
1. Navigate to the Esri WAM Integration master configuration.
2. Set the Inbound Sync Data Filter Option parameter to Filter Statement Builder.
3. Navigate to the GIS to WAM Extendable Lookup.
4. Populate the Filter Statement Builder section to define the feature classes to include in the GIS integration.
5. Review the computed filter statement for accuracy.
6. Using the most recent GIS JAR file, republish the ExtractDeltaChanges GP Service in the GIS Server to use the Filter Statement Builder.
This feature is not supported with the "Work and Asset Management to Geographic Information System Integration - File Based Synchronization Process" feature described elsewhere in these release notes.
ESRI ArcGIS Field Maps - Oracle Field Service Integration
The ESRI ArcGIS Field Maps-Oracle Field Service integration extends the capabilities of the Oracle Field Service mobile solution by bridging the following key GIS functionality from ArcGIS Field Maps:
• Navigation
• Asset Search
• Visualize Assets
• View Asset Properties
• Display Crew Location
• Distance Measuring
• Markup or Map Notes
• Parameterized Deep-linking Between Oracle Field Service Mobile and ArcGIS Field Map Applications for Key Use Cases
• Work Orders
• Work Order or Request Creation from Field Maps (single asset)
• Work Order or Request Creation from Oracle Field Service via Map Selection (single asset)
• Others
• Offline Mode Support
• ArcGIS Online Support
• ArcGIS Enterprise Support
Note: The integration has support for both iOS and Android devices.
Additionally, Oracle Integration Cloud Service facilitates the integration, utility-specific workflows are accessible from both ESRI ArcGIS Field Maps and Oracle Field Service, and data synchronization between the ArcGIS ESRI geodatabase and Oracle Work and Asset Management provides asset information.
Steps to Enable
To enable this feature, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service Configuration Guide for more information.
Construction Work Activity Completion from External System
In this release, the Mobile Activity Completion (W1–MblActCom) API accepts construction work activity completion information such as asset installation, asset removal, service histories creation, measurements creation, and construction location details updates from an external system. The construction work activity is automatically completed once Oracle Utilities Work and Asset Management records all the completion information. In addition, a complete integration solution is now available for construction work activities - Oracle Utilities Work and Asset Management initiates construction work activity, it sends all the necessary construction location and compatible unit information along with the required actions to the external system, W1–MblActCom sends fieldwork information completed in the external system to Oracle Utilities Work and Asset Management automatically records the fieldwork information and completes the activity. Previously, all construction work activity tasks performed in an external system were manually entered in Oracle Utilities Work and Asset Management.
Steps to Enable
To create completion events from the Mobile Activity Completion API, add the following completion event types to the activity's activity type:
• Remove Tracked Asset (W1-RemoveTrackedAsset)
• Remove Non-Tracked Asset (W1-RemoveNonTrackedAsset)
• Install Tracked Asset (W1-InstallTrackedAsset)
• Install Non Tracked Asset (W1-InstallNonTrackedAsset)
• Create Any Service History (W1-CrAnyServiceHistComplEvtTyp)
• Create Operational Reading (W1-CreateOperationalRead)
• Update Construction Location (W1-UpdateConstructionLocation)
Access Requirements
System administrators should set/grant users/grant access to the Execute Completion Events and Completion Error access modes to process completion events from an external system.
Mobile Activity Completion API - Capture Asset Identifier and Asset Attribute Updates
The Mobile Activity Completion (W1–MblActCom) inbound web service now accepts additional updates for asset identifiers (badge number, asset number, and serial number) and asset attributes.
This provides additional updates for asset identifiers and asset attributes.
Steps to Enable
Display Historical Service Histories, Measurements, and Activities on Mobile Changes
The existing Get Asset Details (W1GAstDtlBNo) inbound web service has been enhanced to provide callers with the following options:
• No Service History, Measurements, and Activity History. This is the default behavior when callers don't explicitly specify when calling the service. This was the service's behavior prior to this change.
• Only Service History, Measurements, and Activity History without the other existing asset details.
• Service History, Measurements, and Activity History with the other existing asset details.
• When callers want to retrieve Service History, Measurements, and Activity History, they can specify many filters, for example, number of months' worth of data, Service Category, Service History Type, and Measurement Type.
• When retrieving Service History, callers can choose to retrieve all Questions and Answers if a service history is a questionnaire, as part of this call or not. If they choose no, this service returns an indicator for each retrieved Service History whether there are Questions and Answers and then the caller can choose to call the Get Question and Answer IWS below for a given Service History if needed.
A new Get Question and Answer (W1GetQstnAns) inbound web service has been created which returns the questions and answers for a specific Service History.
Steps to Enable
Mobile Storeroom Inventory - Added Asset Type
The Mobile Storeroom Inventory (W1-MOBILESTOREROOMINVENTORY) inbound web service now includes the asset type for each asset in the inventory. This enables field workers to select the correct asset by matching the asset type on the compatible unit with the asset needed for construction work.
This helps field workers select the right asset by matching the asset type with the one needed for construction work.
Steps to Enable
Activity Assets and Truck Items
The Activity Assets and Truck Items pages have been added to Oracle Field Service Accelerator for Oracle Utilities Work and Asset Management. These pages can be used instead of the standard Assets and Equipment pages.
The Activity Assets page displays the locations and assets, including components, related to the activity:
• The On-Site tab lists the locations with no assets, the installed assets that have not been removed by this activity, and the assets installed by this activity.
• The Issued tab lists the assets issued for the activity that have not been installed.
• The Removed tab lists the assets that have been removed by this activity.
The Truck Item page displays the assets, including components, and items related to the trucks that are included in the activity:
• The Assets tab lists the assets in the resource’s inventory that have not been installed.
• The Items tab lists the item in the resource’s inventory that has not been used.
• The Used tab lists the items in the resource’s inventory that has been used.
Asset or item actions can be performed directly from a list entry. This removes the necessity of navigating first to the Asset or Equipment Details pages before performing these action. The actions available for a location, asset, or item in the Activity Assets or Truck Items pages depend on the location, asset, or item’s current state.
Steps to Enable
Admin Sync Inbound Web Service - Resource Types Status
The status of the Craft, Equipment, and Miscellaneous resource types are now included in the Admin Sync inbound web service.
This notifies the external system of any previously synchronized resource types that have been deactivated.
Steps to Enable
The new file-based synchronization process works with any Geographic Information System (GIS) vendor to load Geographic Information System data into Oracle Utilities Work and Asset Management. This process requires the data to be in GeoJSON newline-delimited format and uses fewer batches to create or update asset and asset locations in Work and Asset Management. GIS File Upload (W1GISUPL) batch control has been introduced to create composite sync requests from the GeoJSON newline-delimited file. Asset and asset location are either created or updated from the composite sync requests. Compared to the Legacy Geographic Information System Integration, this new process requires fewer batches to complete the synchronization.
Additionally, this release includes a W1-GISIntegrationConfiguration admin sync API. This API provides the Geographic Information System to Oracle Utilities Work and Asset Management mapping information needed for file-based integration with external systems.
Steps to Enable
To enable this feature, refer to the GIS File-Based and Legacy GIS Documentation for more information.
The GIS File Upload batch control is secured by the GIS File Upload (W1GISUPL) application service.
Access Requirements
System administrators should grant Execute access to the GIS File Upload (W1GISUPL) application service to any user that will run the batch control.
Get Asset Details Inbound Web Service - Additional Retrieval Filters
The Get Asset Details (W1GAstDtlBNo) inbound web service includes the following options:
• Asset identification support using the GIS Identifier
• Skip Validation flag (Y/N) to specify whether to skip asset installation validations
• Number of Service History, Measurements, and Work History filters (in addition to other filters) to retrieve service history, measurements, and activity history
Also, the existing External Mobile Control Data (W1-ExtMobileControlData) inbound web service now retrieves Measurement Types and Service History Types.
Steps to Enable
Material Issue API
The Material Issue API facilitates the communication of material issues from Oracle Fusion Supply Chain Management to Oracle Utilities Work and Asset Management. Once the material issue is created in Oracle Utilities Work and Asset Management:
• On-demand and reservation quantities are reduced by the issued quantity if the material request is an activity resource requirement. Additionally, if the material request is fully issued, then the status of the activity resource requirement is also updated to Fulfilled.
• On-demand and reservation quantities are cleared regardless of full or partial fulfillment if the material request is a standalone (not for an activity).
Note: There can only be one material issue per request line. If the material is partially issued, a new material request will be required.
Oracle Fusion Supply Chain Management will update the inventory quantity and average unit price of the stock item detail through the Add Inventory Adjustment API.
Steps to Enable
• The following algorithms were added to the Material Issue Line Integration (W1-MaterialIssueLineInteg) business object to support the described behavior:
• Create Stock Transaction for Issue Line (W1-CSKTXISLN): Responsible for reducing the on-demand and reserved quantities.
• Determine and Transition Activity Material Requirement (W1-DETTRNAMR): Responsible for updating the status of the activity resource requirement.
• If the described behavior is not desired, follow these steps to deactivate the algorithms:
1. Navigate to Lifecycle tab of the Material Issue Line Integration BO.
2. Broadcast the Issued status.
3. Click the Edit hyperlink in the Status Details zone.
4. In the Options section, add a new option for Inactive Algorithm, assign a unique sequence number, and set the Option Value to the algorithm that needs to be inactivated.
5. Repeat the steps above if deactivating a second algorithm.
Oracle Field Service Accelerator - Limits on Available Resources
The Admin Sync integration process sets the crafts, equipment, and other resources used in the Oracle Field Service accelerator for Oracle Utilities Work and Asset Management to active or inactive based on the state of the corresponding resource type in Oracle Utilities Work and Asset Management.
Timesheets, equipment usage, and other usage entry in the Oracle Field Service Accelerator for Oracle Utilities Work and Asset Management limits the crafts, equipment, and other resources available for selection to only those that are active.
Steps to Enable
Fixed Asset Extract Data Area - Additional Account Segment and Project-related Fields
Rules and processes were implemented to support a productized integration of fixed asset information to Oracle Assets. Additional fields (for example, account segments and project related fields) are now sent to Oracle Assets.
These provide additional support for fixed assets integration with Oracle Assets.
Steps to Enable
Work Activity API - Additional Asset and Crew Information
The enhanced Work Activity API enables you to pass additional asset information, such as asset attributes, asset numbers, and serial numbers to an external system. With this information, crews can add or update asset attributes and (if permitted) badge numbers, asset numbers, and/or serial numbers. If a crew is specified on the activity, the API passes the information to the external system as the preferred crew and the external system may use or override the preferred crew when scheduling the activity.
Steps to Enable
Work Activity API - User-defined Fields
The following user-defined fields were added to the Work Activity API to enable you to send custom information to an external system:
• activityUDF1 - activityUDF10
• assetUDF1 - assetUDF10
• locationUDF1 - locationUDF10
Note: Custom algorithms and corresponding scripts may be required to populate these fields.
This reduces implementation and support costs.
Steps to Enable
To enable this feature, complete these steps.
1. Navigate to the Work Order Activity Active Outbound Message (W1-WOActivityActiveOutboundMsg) business object.
2. Go to the Algorithm tab and select the Create Algorithm link to create a custom algorithm to populate the additional data to be sent to an external system.
3. Set System Event to Pre-processing.
4. Enter a 12-character code in Algorithm, for example CM-POPADDFLV.
5. Populate the Description and Detailed Description fields.
6. Save the changes.
7. Review the schema to determine the user-defined fields to populate.
Refer to the sample custom algorithm in the Master Demo environment.
2. Go to the Algorithm tab.
3. Review the details of Algorithm: CMPOPADDFIEL (Populate Additional Fields).
Asset Attributes - Viewable in Oracle Field Service
In this release, the Oracle Utilities Work and Asset Management-Oracle Field Service integration enables you to review in Oracle Field Service the asset attributes of a work activity created in Oracle Utilities Work and Asset Management.
This extends the work activity information available in Oracle Field Service.
Steps to Enable
Pass Backlog Group Information to an External System
You can now configure your application to pass the backlog group information of a work activity to an external system. Previously, work activity was assigned to an admin bucket on the external system based on the activity's service area. In some cases, the admin bucket was more similar to the activity's backlog group than the service area that was most likely defined geographically.
This provides external systems with the flexibility to configure where to assign the backlog group information.
Steps to Enable
Questionnaire Details and Failure Information - Exclude from Outbound Activity Message
The Exclude Questionnaire Details and Exclude Failure Information parameters in the Integration Parameters section of Work Management Master Configuration provide the option to send the outbound activity message, questionnaire details, and failure information separately. Previously, the application passed all the questions and answers, and failure information for the asset to the external system via the activity outbound message.
Sending the message and information separately prevents integrations from failing due to large message sizes.
Steps to Enable
1. Go to the Integration Parameters section of the Work Management Master Configuration.
2. Set the Exclude Questionnaire Details parameter to Yes.
3. Set the Exclude Failure Information parameter to Yes.
Installing a Non-Issued Asset for Construction Work
When recording the installation of a tracked asset in Oracle Field Service as part of a construction work activity, the asset to be installed can be identified by either of the following:
• Selecting an issued asset
• Selecting an asset from a truck
• Entering or scanning an asset’s badge number
This provides more flexibility around how assets are installed for construction work activities.
Steps to Enable
Secured Discard Button Enables Manual Discard of Outbound Sync Requests
A 'Manually Discarded' status, which has its own access mode 'W1MD', has been added to the following outbound sync request business objects:
• Activity Material Resource Outbound Integration (W1-ActMatResrcOutboundSyncReq)
• Invoice Outbound Integration (W1-InvoiceIntegOutbound)
• Material Requisition Outbound Integration (W1-MaterialReqIntegOutbound)
• Purchase Requisition Outbound Integration (W1-PurchaseReqIntegOutbound)
• Receipt Outbound Integration (W1-ReceiptOutboundSyncRequest)
• Return Line Outbound Integration (W1-ReturnLineOutboundSyncReq)
• Vendor Location Outbound Integration (W1-VendorLocIntegOutbound)
This gives the ability to manually cancel an outbound sync request when it is not needed anymore, for example, the corresponding update has been manually made in the target system.
Steps to Enable
System administrators should set/grant users/grant access to the new access mode 'W1MD' to application services of the mentioned outbound sync request business objects.
Stock Item Detail Demand Extract Batch Control - Demand Forecasting
To support demand forecasting and replenishment planning within supply chain management, the Stock Item Detail Demand Extract (W1SIDDEX) batch control relays material demand information in Oracle Utilities Work and Asset Management to Oracle Fusion Supply Chain Management.
This batch control creates an extract file containing all Stock Item Details with planned demand and Required By Dates in the future. Oracle Fusion Supply Chain Management uses this information for effective forecasting and replenishment planning. Refer to the Enterprise Resource Planning Integration Master Configuration Demand Forecasting settings for Lead Time (Days), High Demand, and the Additional Demand Calculation setting that define demand quantity calculation. Stock Item Details with an ABC Class of A, B, or C will also be included in the extract, regardless of the Master Configuration settings.
In addition, the Manage Stock Item Detail API has been enhanced to accept ABC Class and Lead Time (Days) information from an external system. This information is used when generating the extract file that is sent to Oracle Fusion Supply Chain Management.
Steps to Enable
The Stock Item Detail Demand Extract batch control is secured by the Stock Item Detail Demand Extract (W1SIDDEX) application service. Users must be granted Execute access to run this batch control.
Access Requirements
System administrators should grant Execute access to the Stock Item Detail Demand Extract (W1SIDDEX) application service to any user that will run the batch control.
Implementation Tools
This section describes the new and enhanced implementation tools features in this release, including:
ESRI-Work and Asset Connector Configuration File - Non-Admin Users
In previous releases, enabling Oracle Utilities Work and Asset to connect to the ESRI Geodatabase and webservices the configuration file deployed in GIS must have the owner of the DEFAULT version in the ESRI Geodatabase and an Admin user of ArcGIS Server. As of this release, the configuration file can be configured with any ERSI Geodatabase user having access to the required feature classes. In addition, the ArcGIS Server user need not be an Admin user to access ArcGIS Server services.
This allows the use of non-admin users for GIS-Work and Asset integrations and supports implementations with policies that do not grant owner or admin users access rights to regular business processes.
Steps to Enable
To enable this optional feature for a Geodatabase user:
1. Configure the Source Version Owner in Esri WAM Integration Master Configuration to be same as the owner of the DEFAULT version in the ESRI Geodatabase.
2. If you are already using GIS-Work and Asset Integration and completed the initial sync process, along with the above create a new private version from the DEFAULT version in the ESRI Geodatabase using the same user as in the configuration file. The name of the version should match the WAM Sync Version in the Esri WAM Integration Master Configuration.
