- Enterprise Limits and Collateral Management Common User Guide
- Limits and Collateral
- Global Block Exposure Maintenance
2.21 Global Block Exposure Maintenance
This topic describes about the detailed information on global block exposure maintenance.
The fields, which are marked with an asterisk, are mandatory.- On the Home screen, specify
GEDEXPBL in the text box and click the
icon.Figure 2-58 Global Block Exposure Maintenance
- On Global Block Exposure Maintenance screen, click
New and specify the fields.For more information on fields, refer to the field description table.
Table 2-60 Global Block Exposure Maintenance - Field Description
Field Description Block No Specify a unique number for the block user are creating. The system does not allow user to modify it after authorization of the maintenance. Branch Click the
icon and select the branch from which the block is
being maintained. User cannot change the branch after
Exposure Code Click the
icon and select the exposure code for which the
amount block is to be done. The adjoining option list
contains all the relevant codes.
Exposure Tupe Specify the exposure type. Utilization type Specify the utilization type. Exposure Description The system defaults the exposure description. Block Currency Click the
icon and select the currency in which the amount
block is to be applied. User cannot modify this once the
maintenance has been authorized.
Block Amount Specify the amount to be earmarked. This amount is deducted from the existing utilization of an exposure before additional utilization requests are processed. Note: It is also updated as the Block Amount in the Track Exposure Maintenance screen.
Effective Date Specify the date from which the amount block should be applied for the exposure. Expiry Date This is the date till which the amount block for the exposure is enforced. Auto Block Swtich to
to enable this parameter.
Swtich to
The system automatically checks this option on the date the block on the exposure comes into force that is, the Effective Date.
to disable this parameter.
Customer No Click the
icon and select the customer number from the
list.
Liability No Specify the liability number for the global exposure block maintenance. Remarks Specify the liability number for the global exposure block maintenance. Line Code Click the
icon and select the line code from the
list.
Serial No Display the serial number from the line code selected. - Click Save to save the record.
Parent topic: Limits and Collateral
