2.1.2.1 Instrument Inventory Summary
  1. On Homepage, specify PISINSNO in the text box, and click next arrow.
    Instrument Inventory Summary screen is displayed.
    Figure 2-4 Instrument Inventory Summary
    Description of Figure 2-4 follows
    Description of "Figure 2-4 Instrument Inventory Summary"
  2. Search using one or more of the following parameters:
    • Authorization Status
    • Record Status
    • Instrument Code
    • Instrument Type
    • Instrument Branch
    • Start Number
    • End Number
  3. Once you specified the parameters, click the Search button.
    System displays the records that match the search criteria.
