Network to Media Control System Maintenance Summary
This topic provides the instructions to view the details of the selected records.
  1. On Homepage, specify PMSNWMCS in the text box, and click next arrow.
    Network to Media Control System Maintenance Summary screen is displayed.
    Figure 2-15 Network to Media Control System Maintenance Summary
  2. Search using one or more of the following parameters:
    • Authorization Status
    • Record Status
    • Host Code
    • Media Control System
    • Network Code
  3. Once you specified the parameters, click the Search button.
    The system displays the records that match the search criteria.
  4. Double click a record after selecting a record to view the detailed screen.
    The selected record is displayed in the detail screen.
