2.1 About Using JDeveloper for Customization
JDeveloper is used when it is needed to customize or create business objects or new pages. The procedures for each of these are different.
New custom objects created in JDeveloper are not saved into the MDS Repository, and so are done in a standard application workspace using the Default role. However, when you customize standard objects, those customizations are saved into the MDS Repository, and so must be done using the Customization Developer role. Doing customizations using the customization developer role ensures that the changes are saved to upgrade-safe MDS Repository, and not written directly to the standard object. In future, when patch or upgrade Application, the customizations held in these metadata files will not be touched, and so, it need not be re-done.
When customizing ADF artifacts, a special customization application workspace can be
created; using the Default role, for this application a default customization
(/OracleFSLLEnterpriseApp/OracleFSLLEnterpriseApp.jws) is
provided. This workspace includes all the artifacts that can be customized. This
customization workspace can be configured, so that when customizations are tested and
deployed, they appear to be part of native Oracle Financial Services Lending and Leasing
Application.
Using the default workspace, it is possible to switch roles to customization developer and customize the ADF artifacts required. After completion, the artifacts are packaged and deployed in the workspace to the Oracle Financial Services Lending and Leasing environment.
Before running JDeveloper in customization mode for the application, see Section 4.3 Enable JDeveloper for Customization for pre-configuration requirement.Parent topic: Using JDeveloper for Customizations
