4.30.2 Initiate and Process Queries
This topic provides information about the initiating and processing queries.
To initiate (or process) a query, in the Help Desk Detail screen, specify the following in the Help Details section:
- The type of entity that is initiating the query, in the Reporting Entity Type field. Also select the ID of the reporting entity in the Reporting Entity ID field.
- The type of query, in the Query Type field. The query could be an inquiry, or an action. Select the appropriate option. The category of the query, in the Query Category field. Choose the required option from the drop down list.
- The degree of criticality of the query, in the Query Severity field.
- If you are following up a previously entered query, select the status of the query in the Status field.
- The description of the report, or query, in the Problem Description field.
- The name of the person who will attend the query, in the Attended By field.
- Also specify the following in the Helpdesk Events section:
- The mode of the query, or the query type, in the Helpdesk Mode field.
- The mode through which the query is being made, in the Event Mode field.
- The description of the query, in the Event Description field.
- Any image, such as a document or fax, regarding the query or report, in the Event Image field. Click the Scan button to specify this.
- Click the Save button to save your query.
Any follow up or processing of the query can likewise be entered in a similar manner, as described above.
Table 4-29 Initiating and Processing Queries
| Fields | Description |
| Helpdesk Reference Number |
Display Every query you initiate in the system is assigned a unique reference number by the system. If you are entering a new query in this screen, this field is empty and locked, and when you specify all the information that is mandatory for initiating a query, the reference number is generated by the system when you Save the information. If you have retrieved a query for viewing or processing, the reference number of the retrieved query is displayed here and it cannot be altered. |
| Attended by | Alphanumeric; 15 Characters; Optional Specify the name of the person who is assigned to attend to the details of the query. |
| Reporting Entity Type | Alphanumeric; 1 Character; Mandatory Specify the type of entity that is initiating the query. Choose from the drop down list. |
| Query Severity | Optional Specify the criticality of the query, by selecting it from the drop-down list. The list displays the following values:
| Reporting Entity ID | Alphanumeric; 12 Characters; Mandatory
Specify the ID of the entity that is initiating the query. |
| Status | Mandatory When you are initiating a new query, this field is locked and has a default value, Open, signifying that the query is yet to be processed. Subsequently, when you retrieve the record of a query in this screen, and edit the same, you can update the status of the query by making the appropriate selection in this field. A query can be open, closed or being followed up. Accordingly, choose the desired option from the drop-down list. The list displays the following values:
| Query Type | Optional Specify the type of query that is being initiated, by selecting it from the drop-down list. The list displays the following values:
| Query Category | Alphanumeric; 6 Characters; Mandatory Specify the subject of the query, by selecting it from the drop down list. |
| Problem Description | Alphanumeric; 255 Characters; Mandatory Narrate the problem, if any, or the statement of the query, in a few words. |
| Helpdesk Events |
You must specify the details of the modes in which any query is initiated or followed up, in this section |
| Helpdesk Mode | Mandatory
For new queries, the mode specified here must be Inquiry. Select the help desk mode from the drop-down list. The list displays the following values:
| Event Date/Time | Display The time at which the query/follow up action was received is displayed here. |
| Event Mode | Mandatory
Select the mode through which the query / follow up action was received. from the drop-down list. The list displays the following values:
| Event Description | Alphanumeric; 255 Characters; Mandatory Give a brief description, if any, about how the query / follow up action was received. |
| Event Object Available |
Indicate from the drop-down list if the event object is available or not. The list displays the following values:
| Event Image |
If the details of the query / follow up action is contained in a document, specify the path to the same here. Click Event Image button to upload the image. |
Parent topic: Help Desk Facility
