3.6.1.2 Multi Transaction Capture Flow
This topic provides the information about the multi transaction capture flow details in the Transaction screen.
PS Out-leg Capture
In the header section the system will capture PS-Out leg details:
Table 3-26 PS Out-leg Capture
Field Description
UH ID Investor ID
Fund ID Switch-out fund ID
Net/Gross Gross/Net
Transaction mode Out leg mode
Multi switch out value Switch-out value
Transaction Currency Should be switch-out fund base currency
PS In-leg Capture
The system captures PS In-leg details as part of the multi record on click of add rows icon.
Table 3-27 PS In-leg Capture
Field Description
Transaction Date Defaulted from header
UH ID Defaulted from header
Fund ID Defaulted from header
Transaction Type Should be switch
Transaction Sub Type Should be Pseudo switch
Transaction Currency Transaction currency
Transaction Mode Only for Amount/Units
Transaction Value Value to be switched
Gross/Net Gross/Net
To Fund ID Switch-in fund ID
On saving, the system generates multi switch wrapper reference number. the reference number will be same as wrapper reference number.
Transaction number will be showing as key string till authorization.
On authorization, the system will update the transaction reference number generated as key string to the actual switch out transaction number. The reference number will be same as wrapper reference number.
Error and overrides will be logged for the PS out transactions.
