Enabling or Disabling Users with System
Administrator and System Authorizer Roles
Perform the following procedure to enable or disable a sysadmn or sysauth
user:
Open the Command Prompt window and go to the folder:
FIC_HOME/utility/useraction/bin.
Execute the following command:
./useraction.sh <ACTION ON USER>
<OPERATION>
For example:
To disable a user:
./useraction.sh johnsmith disableuser
To enable a user:
./useraction.sh johnsmith enableuser
A prompt (Please Enter Action by User) appears, which
requires that you enter your User ID. Your User ID must have the requisite role
with permissions to perform the enable or disable action. Enter the User ID and
the three questions for authentication appear. Enter the correct answers to
complete the password reset.
To enable or disable the users with the Sysadmn or the Sysauth users by
skipping the 3 security questions, use the following command.
