13.1 Create Behavior Pattern Rules
You create behavior pattern rules to capture the principal run-off behavior of product types that do not have contractual maturities.
To create a Behavior Pattern rule, follow these steps:
- Click Add icon from the top of the Behavior Pattern Rule
Summary Page.
Figure 13-1 Creating Behavior Pattern Rule
- Complete standard steps for this procedure.
For more information, see the Overview of Common Rule Management Tasks section.
In addition to the standard steps for creating Rules, the procedure for creating a Behavior Pattern Rule involves one extra step. After Standard Step, you need to select a product hierarchy. For more information, see the Overview of Common Rule Management Tasks section. You can define methodologies at any level of the hierarchical product dimension. The Hierarchical Relationship between nodes allows the inheritance of methodologies from parent nodes to child nodes.
Oracle Asset Liability Management provides you with the option to copy, in total or selectively, the product assumptions contained within ALM business Rules from one currency to another currency or a set of currencies or from one product to another product or a set of products.
