13 Behavior Pattern Rule
The Behavior Pattern (BP) functionality works similarly to amortization types. The Behavior Pattern code is assigned at the detail instrument level, and these designations are evaluated by the cash flow engine (CFE) for calculations. However, Behavior Patterns are portfolio level property rather than instrument level. Generally, a bank processes aggregated data for non-maturing products. In this case, the Behavior Pattern is assigned effectively at the portfolio level. If you are using CFE with any other service, then data is required at the instrument level and BP is also assigned accordingly.
In this case, you must track the changes to Behavior Patterns and assign appropriate codes to affected instruments. Due to this, only one BP can be used by the CFE in the CFE processes for current business. If you want to model multiple types of BP under varying scenarios, then you can use a Behavior Pattern Rule.
The Behavior Pattern Rule UI allows you to group Behavior Pattern codes (behavioral assumptions) together in a set at the Product/Currency level which then can be rotated to select a value on a combination. You can select which behavior assumption pattern to use and the underlying Behavior Pattern in that set will affect the data on processing
This chapter describes the procedure for working with and managing the Behavior Pattern rules.
Topics
- Search Behavior Pattern Rule. For more information, see the Searching for Rules section.
- Create Behavior Pattern Rule
- View and Edit Behavior Pattern Rule. For more information, see the View and Edit the Rule section.
- Copy Behavior Pattern Rule. For more information, see the Copy the Rule section
- Delete Behavior Pattern Rule. For more information, see the Delete the Rule section
