12.5 Deleting Repricing Pattern
You can delete patterns that are no longer required.
A pattern cannot be retrieved after deletion.
Restrictions on deleting patterns are:
  • You cannot delete patterns if you have only Read privileges. Only users with read/write privileges and pattern owners can delete patterns.
  • You cannot delete a pattern that has a dependency.
To delete a Repricing Pattern, follow these steps:
  1. Navigate to the Repricing Pattern Summary page of the pattern you want to delete.
  2. Search for a pattern.
    For more information, see the Searching for Rules section.
  3. Select the appropriate pattern and click Delete
