12.4 Copying Repricing Pattern
You can copy patterns to avoid having to enter data multiple times. This saves time and effort and also reduces mistakes.
To copy a Repricing Pattern, follow these steps:
- Navigate to the Repricing Pattern Summary page of the pattern you want to copy.
- Search for a pattern.
For more information, see the Searching for Rules section.
- Select the appropriate pattern and click Copy to duplicate the pattern.
- Select a folder where you want to save the pattern copy.
- Enter a unique name for the new pattern.
(Optional) Enter a brief description of the pattern.
- Select the access type.
- Click the Save button.
