12.3 Viewing and Editing Repricing Pattern
You can view existing Repricing Pattern, and you can edit existing patterns, provided you have read/write privileges.
To view and edit a Repricing Pattern, follow these steps:
  1. Navigate to the Repricing Pattern Summary page of the pattern you want to update.
  2. Search for a pattern. For further information, see the Searching for Rules section.
  3. Select the appropriate pattern and click Edit to open the pattern you want to update.
  4. Update the Name or Description.
  5. Click Apply or Save, depending on the pattern type.
