9.6 Deleting Rules
You can delete rules that are no longer required.
A rule cannot be retrieved after deletion.
Restrictions on deleting rules are:
- You cannot delete rules if you have only Read privileges. Only users with read/write privilege and rule owners can delete rules.
- You cannot delete a rule that has a dependency.
To delete a rule, follow these steps:
- Navigate to the Rule Summary page of the Rule you want to delete.
- Search for a Rule. For further information, see the Searching for Rules section.
- Select the appropriate Rule and click Delete.
For more information, see the Overview of Common Rule Management Taskssection.
To delete a rule in Cash Flow Edit window, follow these steps:
For more information, see the Searching for Rules section.
- Click in the Action column and select Delete.
