21.3 Input Values for OBJECTMIGRATION.xml
Tableshows the list of Input Attributes of the OBJECTMIGRATION.XML file.
Table 21-2 List of Input Attributes of OBJECTMIGRATION.XML file
| Object Name | Object Type Id | Input value in OBJECTMIGRATION.XML for the wild card | Input value in OBJECT_MIGRATION.xml for Object Code |
| Application Preferences | 201 |
<OBJECT Code=”CONFIG” Type=”201”/> |
| Interest Rates | 801 | <OBJECT Code=”User defined unique code” Type=”801”/> | |
| Currency Rates | 803 | <OBJECT Code=”System generated code” Type=”803”/> | |
| Currencies | 802 | <OBJECT Code=”User defined unique code” Type=”802”/> | |
| Economic Indicator | 804 | <OBJECT Code="System generated code" Type="804"/> | |
| Filter | 1 | <OBJECT Code="System generated code" Type="1"/> | |
| Payment Patterns | 809 | <OBJECT Code="User defined unique code" Type="809/> | |
| Repricing Patterns | 808 | <OBJECT Code="User defined unique code" Type="808"/> | |
| Behavior Patterns | 807 | <OBJECT Code="User defined unique code" Type="807"/> | |
| Prepayment Rules | 300 | <OBJECT Code="System generated code" Type="300"/> | |
| Prepayment Models | 312 | <OBJECT Code="System generated code" Type="312"/> | |
| Forecast Rate Scenarios | 11003 | <OBJECT Code="System generated code" Type="11003"/> | |
| Cash Flow Engine Process | 11001 | <OBJECT Code="System generated code" Type="11001"/> | |
| Cash Flow Edits | 11002 | <OBJECT Code="System generated code" Type="11002"/> |
$FIC_HOME /utility/Migration/logs/offline_migration.log<War_deployed_location>/logs /FUSIONSUBSYSTEMSService.log
