22 Standard Navigation Paths
This section provides information to navigate through the pages referred to in this guide. Oracle Financial Services Cash Flow navigation paths are displayed in the List of Navigation Paths. Access all these pages through the CFE Administrator or CFE Analyst responsibility.
Table 22-1 List of Navigation Paths for Oracle Financial Services Cash Flow Application
| Page | Navigation Path |
| Application Preferences | Select Cash Flow Engine menu and select Application Preferences |
| Behavior Pattern Home | Select Cash Flow Engine menu, and then select Patterns. Navigate to Behavior Patterns. |
| Payment Pattern Home | Select Cash Flow Engine menu, and then select Patterns. Navigate to Payment Patterns . |
| Repricing Pattern Home | Select Cash Flow Engine menu, and then select Patterns. Navigate to Repricing Patterns. |
| Interest Rate Code Home | Select Common Object Maintenance, select Rate Management, and then select Interest Rates. |
| Currency Rates Home | Select Common Object Maintenance, select Rate Management, and then select Currency Rates |
| Currencies Home | Select Common Object Maintenance, select Rate Management, and then select Currencies. |
| Economic Indicator Home | Select Common Object Maintenance, select Rate Management, and then select Economic Indicators |
| Prepayment Rule Home | Select Cash Flow Engine menu, select Assumption specification, and then select Prepayments |
| Prepayment Models Home | Select Cash Flow Engine, select Assumption specification, and then select Prepayment Models |
| Forecast Rates | Select Cash Flow Engine menu, select Assumption Specification, and then select Forecast Rates |
| Behavior Pattern Rule Home | Select Cash Flow Engine, select Assumption specification, and then select Behavior Pattern Rule |
| Cash Flow Process Home | Select Cash Flow Engine menu, select Processing, and then select Cash Flow Process |
| Cash Flow Edits Process | Select Cash Flow Engine menu, select Processing and then select Cash Flow Edits |
| Cash Flow Reports | Select Cash Flow Engine menu, select Reports and then select Cash Flow Report |
| Cash Flow Configuration | Select Cash Flow Engine menu, and then select Configuration |
