5.11.2.9 Executing LEDGER_STAT Load Procedure
You can execute this procedure either from SQL*Plus or from within a PL/SQL block or from Batch Maintenance window within OFSAAI framework.
To run the procedure from SQL*Plus, login to SQL*Plus as the Schema Owner. The procedure/batch requires the following 9 parameters:
- BATCH_ID- Any unique number to identify the execution run.
- MIS_DATE- Date on which the loading is done expressed in YYYYMMDD format.
- TABLE_NAME- STG_GL_DATA(Type III) or any other load table (TYPE I or TYPE II)
- TABLE_TYPE- FISCAL_ONE_MONTH or FISCAL_RANGE (TYPE I or TYPE II)
- CALENDAR_MONTHS (TYPE III)
- UPDATE_MODE- ADD/REPLACE
- INSERT_ONLY- Y/N
- START_DATE- Calendar start date in YYYYMMDD
- END_DATE- Calendar end date in YYYYMMDD
The input parameter logic for the Type III, Type II and Type I tables.
