PreviousNext
JavaScript must be enabled to correctly display this content
4.5.3 Executing Undo Engine
To execute Undo Engine, follow these steps:
To execute the engine from OFSAAI Batch Maintenance, create a new Batch with
the Task as RUN EXECUTABLE and specify the following parameters for the
task:
Datastore Type: Select appropriate datastore from
list
Datastore Name: Select appropriate name from the
list
