5.11.2.7 Tables Related to LEDGER_STAT Load Procedure
LEDGER_STAT Loader utility uses the following tables:
FSI_FISCAL_YEAR_INFO:The table contains the fiscal year information. This is a setup table.FSI_LS_LOAD_BATCH:The table contains the parameters for the load batch that needs to be executed for loading ledger data from staging or load table into LEDGER_STAT. This is a setup table.STG_GL_DATA:The staging table contains the ledger data for various as-of-dates.-
LEDGER_STAT:The processing table contains the ledger data for various fiscal months. This is loaded from staging table.
