PreviousNext
JavaScript must be enabled to correctly display this content
7.5 Applying General Ledger Filters for
Revaluation
To apply General Ledger Filters for revaluation:
In the SETUP_MASTER table in atomic schema, update the column V_COMPONENT_VALUE
with the dimension column name.
Example: N_GL_ACCOUNT_SKEY where V_COMPONENT_CODE='REVAL_FILTER_DIM_ATT'
In the revaluation pipeline of PMF, add a custom task before executing
revaluation task. This should populate the FSI_BCE_REVAL_FILTERS table with Run
SKEY, v_dim_Att ( GL_ACCOUNT_SKEY) and n_dim_val (the dimension filter to be
applied).
Execute the revaluation rule in PMF and verify if filters are applied in the
output table for the given Run SKEY.
