9.4.3 Use Standard OFSBCE Run Pipelines
After OFSBCE is installed successfully, the following standard Run pipelines (pipelines are PMF processes) are available out of the box in the PMF:
  • Balance Computation Management Ledger process
  • Balance Revaluation Management Ledger process
  • Translate Management Ledger Period Balances process
If there are any failures during the BCE run execution, perform the below steps:
  • delete from FSI_MGMT_LGR_PERIOD_BALANCES where N_RUN_SKEY=? and N_MIS_DATE_SKEY = ?;
  • delete from FSI_MGMT_LGR_DAILY_BALANCES where N_RUN_SKEY=? and N_MIS_DATE_SKEY = ?;
