5.6.4 Running a Single Task Using a Batch
From the Batch Execution page, you can also run a single task from a batch.
Running a single task using a batch is not a recommended approach and should be done only for debugging a particular task.- Login as the Alert Viewer Administrator. The OFSAAI Applications page is displayed.
- Click Financial Services Money Laundering.
- In the Navigation List, select Common Tasks, then select Operations, then Batch Execution. The Batch Execution page is displayed.
- In the Batch Details section, select the particular batch that you want to execute.
- In the Task Details section, click Exclude/Include. The Task Mapping window is displayed.
- Retain the tasks that you want to execute under Available Tasks section and move the rest to the Set Tasks section.
- Click OK. The following warning message is displayed: If you exclude a task, it will be skipped when executing the batch but, the precedence will not be altered. Do you want to exclude the selected tasks)?
- Click OK.
- Click Execute Batch.
