5.6.1 Management Ledger
The Management Ledger Report provides the analysis capability on the Management Ledger Table.
You can use a series of Report Prompts to filter the data according to Functional Key Attributes pertaining to the Table Columns Perimeter.
The report displays the underlying data according to the following Charts’ logic:
  • Management Ledger - Number of Records Trend
    Total Records Management Ledger aggregated by AS_OF_DATE.
  • Management Ledger
    Granular table records at FINANCIAL_ELEM_ID level.
Figure 5-29 Processing Ledger Data – Management Ledger
