5.6.2 Management Ledger01
The Management Ledger01 Report provides the analysis capability on the Placeholder Management Ledger 01 Table.
You can use a series of Report Prompts to filter the data according to Functional Key Attributes pertaining to the Table Columns Perimeter.
The report displays the underlying data according to the following Charts’ logic:
  • Management Ledger01 - Number of Records Trend
    Total Records Management Ledger01 aggregated by AS_OF_DATE.
    Granular table records at FINANCIAL_ELEM_ID level.
Figure 5-30 Processing Ledger Data – Management Ledger01
