2.1 Currency Summary Page
This page is the gateway to all Currencies and related functionality. You can navigate to other pages relating to Currency from this point. The Currency Summary Page displays the following columns.
Table 2-1 Table: Currency – Fields and Descriptions
Column Description
Code Displays the 3-letter ISO code of Currency
Name Displays the name of currency
Reference Interest Rate Curve Displays the Reference Interest Rate Curve of Currency
Reporting Currency Indicates whether currency is marked for use as Reporting Currency
Status Displays the Active or Inactive status of Currency.
User Defined Identifies any user-defined currency, i.e. a currency not seeded by PBSM
Last Modified By Displays the Name of the user who last modified the Currency
Last Modified Date Displays the Date and Time when Currency was modified last
Action Displays the list of actions that can be performed on the Currency. For more information, see Table 2-2 .
Figure 2-1 Currency Summary Page
The Action column on the Currency Summary page and icons on top right of the page offers several actions that allow you to perform different functions. The following actions are available for the Currency.
Table 2-2 Table: Currency– Icons and Descriptions
Fields Description
Activate Select one or more currency and click Activate icon to change status to active.
Add Click Add icon to create a new Currency.
Multiple Delete Select one or more currencies in the table and then click the Delete icon at the top right of the summary page to delete more than one Currencies at the same time.
View/Edit Click on the Action icon against the Currency Name and select View/Edit to view or edit the contents of a Currency in read/write format. Depending on user privileges the currency will open in either View or Edit mode.
Delete Click on the Action icon against the Currency Name and select Delete to delete an existing Currency.
