2.7 Dependency Check
You can check dependencies for rules to know where a particular Repricing Pattern Rule has been used. This also prevents accidental deletion of rules having dependencies.
To check the dependency of a rule, follow these steps:
- Navigate to the Maintenance and select Repricing Pattern.
- Search for a Rule. For further information, see the Searching for Rules Section.
- Click on the Action icon against the Pattern Name and select Dependency Check to the Rule that you want to check for.
This is functionality will be released in future.
