2.6 Delete Repricing Pattern
You can delete patterns that are no longer required.
A pattern cannot be retrieved after deletion.
Restrictions on deleting patterns are:
- You cannot delete patterns if you have only Read privileges. Only users with Read/Write privileges and pattern owners can delete patterns.
- You cannot delete a pattern that has a dependency.
To delete a Repricing Pattern, follow these steps:
- Navigate to the Maintenance and select Repricing Pattern.
- Search for a Rule. For more information, see the Searching for Rules section.
- Click on the Action icon against the Pattern Name and select Delete.
