2.5 Copy Repricing Pattern
You can copy patterns to avoid having to enter data multiple times. This saves time and effort and also reduces mistakes.
To copy a Repricing Pattern, follow these steps:
- Navigate to the Maintenance and select Repricing Pattern.
- Search for a Rule.
For more information, see the Searching for Rules section.
- Click on the Action icon against the Pattern Name and select Save As to duplicate the rule.
- Select a folder where you want to save the Rule Copy.
- Enter a unique name for the new Rule.
- (Optional) Enter a brief description of the Rule.
- Select the access type.
- Click Save.
